Get reliable, high-speed scanning for complex projects – this scanner can handle 3,000 sheets per day. Scan both sides of the page at up to 50 images (25 pages) per minute. HP EveryPage helps avoid misfeeds and simplifies your workflow.
Fast, reliable two-sided scanning
Produce up to 50 images (25 pages) per minute with two-sided scanning. Reliably scan 3,000 sheets per day.Capture every page easily – even for stacks of mixed media – with HP EveryPage and an ultrasonic sensor.Scan documents up to 21.6 x 309.9 cm (8.5 x 122 in) through the ADF, and use the flatbed for bulky media.Spend less time waiting – scans reach their destination at fast speeds with a USB 3.0 connection. -
Work smarter with quick, simple scanning
Define scan profiles for common document types and scan to multiple destinations with HP Scan software.Create one-button scan settings for recurring tasks and make selections using the LCD control panel.Quickly share or archive scans directly to popular cloud destinations with HP Scan software.Scan directly into applications without opening another program with HP's full-featured TWAIN driver. -
Sharp images and accurate text capture
Accurately capture text from documents for easy editing with HP Scan and I.R.I.S. Readiris Pro OCR software.Get sharp, true-to-life scans of documents, graphics, and photos with up to 1200 dpi resolution.Book-edge scanning prevents distorted text, even near the spine of books and other bound materials.Auto-imaging features in the included HP Scan software let you enhance images and delete blank pages.
- HP Scanjet Pro 3500 f1 - document scanner - desktop - USB 3.0
- Document scanner - desktop
- Interface Type
- USB 3.0
- Scanning Sensor Type
- CMOS / CIS
- Light Source
- LED
- Max Supported Document Size
- 216 x 3100 mm
- Localisation
- English, German, French, Italian, Spanish / Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 25 ppm (mono) / 25 ppm (colour)
- Max Document Size
- 216 mm x 3100 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, plastic card, labels, photo, envelope
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 3000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10 (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- 46 cm x 38.7 cm x 14.5 cm
- 5.58 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 3.0
- 216 x 3100 mm
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 24-bit (16.7 million colours)
- Scan Mode
- Single-pass
- CMOS / CIS
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 25 ppm
- Max Document Scan Speed Colour
- 25 ppm
- Control Panel Buttons Functions
- Scan, cancel, duplex, tools
- Duty Cycle
- Scanner Speed Details
- 25 ppm - 300 dpi , 50 ipm - duplex - 300 dpi (front) / 300 dpi (back)
- Scanner Features
- Built-in LCD screen
- TWAIN, WIA
Media Handling
- Max Document Size
- 216 mm x 3100 mm
- Supported Document Size Details
- ADF - up to 216 x 3100 mm , Flatbed - up to 216 x 297 mm
- Automatic
- 50 sheets
- Interfaces Details
- USB 3.0
- Cables Included
- 1 x USB cable
- C-Tick, BSMI, CISPR 24, cUL, EN 61000-3-2, EN55022, ICES-003, SASO, EN 61000-3-3, CISPR 22, CCC, EMC, RoHS, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, KCC, BSMI CNS 13438, FCC CFR47 Part 15 B, CSA C22.2 No. 60950-1 Second Edition, KN22, EAC, TER, PVOC, CoC
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Stand by
- 4.51 Watt
- Power Consumption Sleep
- 1.4 Watt
- Software Included
- Readiris Pro, Cardiris, Nuance PaperPort, HP Scan, HP Scanner Tools Utility
- OS Required
- System Requirements Details
- Windows 7/8/8.1/10 - 2 GHz - RAM 2 GB - HD 170 MB , MacOS X 10.9/10.10 - RAM 1 GB
- 46 cm
- 38.7 cm
- 14.5 cm
- 5.58 kg
- Shipping Width
- 57.9 cm
- Shipping Depth
- 49.9 cm
- Shipping Height
- 24.5 cm
- Shipping Weight
- 7.6 kg
- Limited warranty - 1 year
- 10 °C
- 35 °C
- 15 - 80% (non-condensing)
