Turn the page on time-consuming, manual document handling. This intelligent scanner is easy to use and makes any office more efficient. Get clear, crisp digital documents every time – and cut your power consumption with this energy-efficient device.
Save time, skip manual steps, be more efficient and create one-click short cuts with HP Easy Scan
Spend less time digitising documents and more time doing business.Accurately capture the right results with auto-scan mode, crop and colour detection.Work smarter with intuitive shortcuts and HP Easy Scan. Create PDF files with a single touch and easily plug right in to existing scanning platforms.Seamlessly add high-volume scanning to existing processes with HP TWAIN, ISIS, WIA, Linux and Mac drivers. -
Avoid lost pages in scanned files
Make missed pages a thing of the past. The HP Scanjet Pro 3000 s2 Sheet-feed Scanner individually feeds and auto-aligns each page.Quickly scan files and get crisp, clean results again and again with a scanner that works hard for your business.Whether close at hand, or centrally situated, with its compact design the HP Scanjet Pro 3000 s2 Sheet-feed Scanner fits into even the busiest offices.Scan at up to 600dpi and rely on a device that just won't quit – scan up to 1,000 pages per day. -
Start fast and keep going
Waste less paper and ink, by scanning, storing and sharing documents digitally. And you cut down on clutter.Manage costs with an ENERGY STAR qualified scanner. Reduce energy use without slowing down, and start scanning quickly from low-power mode.Cut your environmental impact with a scanner that's fully RoHS-compliant and free of mercury, lead and other hazardous materials.And you enjoy complete peace of mind with a one-year limited warranty, including quick phone or online support from HP.
- HP Scanjet Pro 3000 s2 - sheetfed scanner - desktop - USB 2.0
- Sheetfed scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- LED
- Max Supported Document Size
- 215.9 x 864 mm
- Localisation
- English, German, French, Italian, Spanish / Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Size
- 215.9 mm x 864 mm
- Automatic Duplexing
- Document Feeder Type
- Automatic
- Duty Cycle
- 1000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Apple MacOS X Lion 10.7, Apple MacOS X 10.6.8, Apple OS X 10.8 Mountain Lion, Microsoft Windows Vista / XP / 7 / 8
- 28.5 cm x 16.1 cm x 16.4 cm
- 2.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 215.9 x 864 mm
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Bulb / Light Source Type
- LED
- Control Panel Buttons Functions
- Scan, cancel
- Duty Cycle
- Scanner Speed Details
- 20 ppm - 300 dpi (front) / 300 dpi (back) , 40 ipm - duplex - 300 dpi (front) / 300 dpi (back)
- Scanner Features
- Ultrasonic Multi Feed Detection
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 215.9 mm x 864 mm
- Supported Document Size Details
- ADF - up to 215.9 x 864 mm
- Automatic
- USB 2.0
- Cables Included
- 1 x USB cable
- GOST, CISPR 24, EN55022, SASO, EN55024, CISPR 22, EMC, RoHS, IEC 60950-1, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 61000-3-2:2006, EN 61000-3-3:2008, EN 60950-1:2006
- ENERGY STAR Certified
- Voltage Required
- Power Consumption Operational (Standby)
- 11.6 Watt (5.9 Watt)
- Software Included
- Readiris Pro 14, HP Easy Scan, Nuance PaperPort 14, Cardiris Pro 5
- OS Required
- System Requirements Details
- Windows Vista/7/8 - 2 GHz - RAM 2 GB - HD 177 MB , Windows XP SP3 - 1.6 GHz - RAM 1 GB - HD 177 MB
- 28.5 cm
- 16.1 cm
- 16.4 cm
- 2.3 kg
- Shipping Width
- 38 cm
- Shipping Depth
- 28.5 cm
- Shipping Height
- 21.6 cm
- Shipping Weight
- 4 kg
- 10 °C
- 35 °C
- 15 - 80%
