HP ScanJet N6350 A4 Scanner
HP Scanjet N6350 Networked Document Flatbed Scanner
Quicklinx: 62GXWS00 Mfr#: L2703A#BEA
Enhance workteam productivity – share a range of advanced document capture tools over your wired Ethernet network. This PC-connected scanner lets you scan multi-page documents – single or double-sided – and share to networked folders or via email.
  • Share robust, versatile performance across multiple users via integrated networking
    Share advanced scanning tools between multiple users – just connect to an existing Ethernet network, no IT expertise necessary. Easy sharing and sending of digital files direct from the scanner. Optional PIN security. ISIS , TWAIN and WIA drivers.
  • Scan multi-page documents quickly and reliably with the duplex automatic document feeder
    Boost office productivity with unattended document capture. Load up to 50-sheets into the automatic document feeder and scan at up to 15 ppm/6 ipm. Handle business cards, stapled documents, photos and slides/negatives using the flatbed scanner.
  • Streamline your scanning processes with easy shortcuts and automatic image enhancement
    Improve efficiency with a task-based user interface and one-touch 'scan' and 'copy' buttons. Set shortcuts to common tasks such as scan-to-PDF. Automatically deskew, crop and rotate, and choose colour drop-out to improve OCR accuracy.
HP ScanJet N6350 Networked Document Flatbed Scanner - flatbed scanner - USB 2.0, LAN
Flatbed scanner
Interface Type
USB 2.0, LAN
Scanning Sensor Type
CCD
Max Supported Document Size
220 x 356 mm
Input Type
Grayscale / Color Depth
48-bit colour
Optical Resolution
2400 dpi x 2400 dpi
Scan Speed
15 ppm
Max Document Size
216 mm x 292 mm
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions)
Microsoft Certification
Certified for Windows Vista
50.2 cm x 41.5 cm x 16.8 cm
6.7 kg
Environmental Standards
ENERGY STAR Qualified
Flatbed scanner
Interface Type
USB 2.0, LAN
220 x 356 mm
Scanner
Input Type
Colour Depth
48-bit colour
Optical Resolution
2400 dpi x 2400 dpi
CCD
Scan Speed
15 ppm
Control Panel Buttons Functions
Scan, copy, cancel, setup
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 292 mm
Supported Document Size Details
ADF - up to 220 x 356 mm , Flatbed - up to 216 x 292 mm
Automatic
50 sheets
USB 2.0 - Type B , LAN
Transparency adaptor
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ENERGY STAR Certified
Internal power supply
Software Included
Drivers & Utilities, Readiris Pro, ScanSoft PaperPort, Presto! BizCard
Additional Requirements
CD-ROM, SVGA monitor
50.2 cm
41.5 cm
16.8 cm
6.7 kg
Shipping Width
58.8 cm
Shipping Depth
54.7 cm
Shipping Height
24.8 cm
Shipping Weight
8.2 kg
10 °C
35 °C
15 - 80%
