HP Scanjet N6310
HP Scanjet N6310 Document Flatbed Scanner
HP Scanjet N6310
Quicklinx: 70RHWS00 Mfr#: L2700A#B19
Manage all your office scanning – single or double-sided documents, bound reports, business cards, photos and even slides and negatives – from one versatile machine. Boost productivity with document enhancement and programmable shortcuts.
  • Capture everything from single receipts to stacks of papers with this ultra-versatile scanner
    Put an advanced document capture device at the heart of your business and get versatile image scanning from the same machine. Scan it all – stacks of papers, bound or stapled documents, business cards, photos, 35 mm slides and negatives.
  • Streamline your scanning processes with easy shortcuts and automatic image enhancement features
    Complete common tasks more efficiently with one-touch shortcuts. Use HP scanning technology to automatically deskew, crop and rotate digitised files. Choose colour-drop-out to improve OCR accuracy when turning documents into editable digital files.
  • Scan multipage documents quickly and reliably with the duplex automatic document feeder
    Boost office productivity with easy unattended document capture using the 50-sheet duplex automatic document feeder. Scan at up to 15 ppm/6 ipm. Preview, edit and adjust scans using HP Scanning Software. ISIS , TWAIN and WIA drivers included.
HP ScanJet N6310 Document Flatbed Scanner - flatbed scanner - USB 2.0
Flatbed scanner
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Max Supported Document Size
220 x 356 mm
Input Type
Grayscale / Color Depth
48-bit colour
Optical Resolution
2400 dpi x 2400 dpi
Scan Speed
15 ppm
Max Document Size
216 mm x 292 mm
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions), Apple MacOS X 10.5 or later, Apple MacOS X 10.4.11
Microsoft Certification
Certified for Windows Vista
50.2 cm x 41.5 cm x 16.8 cm
6.7 kg
Environmental Standards
ENERGY STAR Qualified
Flatbed scanner
Interface Type
USB 2.0
220 x 356 mm
Scanner
Input Type
Colour Depth
48-bit colour
Optical Resolution
2400 dpi x 2400 dpi
CCD
Scan Speed
15 ppm
Control Panel Buttons Functions
Scan, copy, cancel, setup
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 292 mm
Supported Document Size Details
ADF - up to 220 x 356 mm , Flatbed
Automatic
50 sheets
Interfaces Details
USB 2.0 - Type B
Transparency adaptor
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
Internal power supply
Software Included
Drivers & Utilities, Presto! PageManager, Readiris Pro, ScanSoft PaperPort, Presto! BizCard
Additional Requirements
CD-ROM, SVGA monitor
System Requirements Details
Windows XP Home/Pro - 1.3 GHz - RAM 512 MB - HD 450 MB , Windows Vista - 1.3 GHz - RAM 1 GB - HD 450 MB , Windows 2000 - 800 MHz - RAM 256 MB - HD 450 MB
50.2 cm
41.5 cm
16.8 cm
6.7 kg
10 °C
35 °C
15 - 80%
