HP Scanjet G4010 Photo Scanner
Quicklinx: 4BNBWS00 Mfr#: L1956A#B19
Get superior colour accuracy with innovative 6-colour photo scanning – exclusive to HP. Scan slides and negatives too, capturing every detail with 4800 x 9600-dpi hardware resolution. Restore faded colours and fix old photos and slides.
  • HP-exclusive 6-colour high-definition photo scanning plus slide and negative adapter
    Capture colours that are 40% more accurate than other scanners with HP's exclusive 6-colour, 96-bit scanning. Scan slides and negatives too using the built-in adapter, and get crisp, high definition results at 4800 x 9600-dpi resolution.
  • Preserve your memories – intuitive tools help you restore old or damaged originals
    Bring old photos, slides and negatives back to life with a range of intuitive tools including easy dust and scratch removal. Restore faded colour, remove red-eye and bring detail out of dark photos, all using HP Real Life technologies.
  • Scan via convenient one-touch buttons, and edit and share using included software
    Enjoy fast, convenient one-touch photo or slide/negative scanning. Make copies and reprints at the touch of a button too, and save files as PDFs for easy sharing. Organise, edit and email photos with easy-to-use HP Photosmart Software.
HP ScanJet G4010 Photo Scanner - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Max Supported Document Size
216 x 311 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 96-bit colour
Optical Resolution
4800 dpi x 9600 dpi
Max Document Size
216 mm x 311 mm
Supported Document Type
Plain paper, slides, bulk objects (such as books, magazines and other bound materials), film
Document Feeder Type
Manual
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Media Center Edition 2005, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.4 or later
Microsoft Certification
Certified for Windows Vista
30.3 cm x 50.8 cm x 9.8 cm
4.4 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 311 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
96-bit colour
Optical Resolution
4800 dpi x 9600 dpi
CCD
Control Panel Buttons Functions
Scan, copy, Scan film, Scan-to-PDF
Scanner Speed Details
29 sec/scan - photo - colour - 10x15cm , 25 sec/scan - OCR - A4 , 24 sec/scan - film (positives) - 35mm , 39 sec/scan - film (negatives) - 35mm , 8.5 sec/scan - preview
Scanner Features
HP Real Life Technologies
TWAIN
Media Handling
Max Document Size
216 mm x 311 mm
Manual
Interfaces Details
USB 2.0
Transparency adaptor, film holder
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
UL, BSMI, GOST, cUL, CCC, MIC, FCC, IEC 60950-1, ACA
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
25 Watt
Software Included
Drivers & Utilities
System Requirements Details
MacOS X 10.3.9 or later - PowerPC G3 RAM 128 MB - HD 250 MB (USB) , Windows 2000/XP - Pentium II - 233 MHz - RAM 128 MB - HD 500 MB (USB)
30.3 cm
50.8 cm
9.8 cm
4.4 kg
10 °C
35 °C
0 - 90%
