Enjoy easy scanning at the touch of a button with this stylish, affordable scanner. Get great results from your photos, slides and negatives, then enhance or restore them using intuitive software. Scan and manage documents for easy archiving too.
Get more from your photos with high-quality scanning and easy restoration
Turn your photos into high-quality, easy-to-share digital images with 4800 x 9600 dpi resolution and 48-bit colour. Remove red-eye, improve contrast, restore faded colour and remove dust and scratches using included software. -
Scan multiple photos, slides, negatives or even 3-D objects and save to separate files
Scan multiple originals – up to four 35 mm slides, five negatives or three 10 x 15 cm photos – at once and save as separate files. Get impressive results from open books, framed pictures and even 3-D objects such as jewellery or collectables. -
Turn paperwork into editable documents and easy-to-archive digital files
Turn important documents into easy-to-archive PDF files or convert them into editable text using the Optical Character Recognition (OCR) software. Enjoy the speed and convenience of one-touch Copy and Scan-to-Email buttons too.
- HP ScanJet G3110 Photo Scanner - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- 220 x 300 mm
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 48-bit colour
- Optical Resolution
- 4800 dpi x 9600 dpi
- Max Document Size
- 220 mm x 300 mm
- Supported Document Type
- Transparencies, plain paper, slides
- Document Feeder Type
- Manual
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Media Center Edition, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Apple MacOS X 10.4.11
- Microsoft Certification
- Certified for Windows Vista
- 30.5 cm x 45.5 cm x 7 cm
- 2.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 220 x 300 mm
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- CCD
- Control Panel Buttons Functions
- Scan, copy, Scan-to-Email, Scan-to-PDF
- Scanner Speed Details
- 28 sec/scan - photo - colour - 10x15cm , 28 sec/scan - OCR - A4 , 26 sec/scan - film - 35mm , 21 sec/scan - photo - colour - 10x15cm , 28 sec/scan - A4 , 11 sec/scan - preview
- TWAIN
Media Handling
- Max Document Size
- 220 mm x 300 mm
- Manual
- Interfaces Details
- USB 2.0 - Type B
- Included Accessories
- Transparency adaptor
- Cables Included
- 1 x USB cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- TUV GS, BSMI, GOST, cUL, CB, CCC, MIC, FCC, UL 60950-1, IEC 60950-1, EN 60950-1
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 15 Watt
- Software Included
- HP Photosmart Essential
- OS Required
- System Requirements Details
- Windows 2000/XP - 500 MHz - RAM 128 MB - HD 450 MB (USB) , Windows Vista - 800 MHz - RAM 512 MB - HD 450 MB (USB)
- 30.5 cm
- 45.5 cm
- 7 cm
- 2.9 kg
- Shipping Width
- 54.2 cm
- Shipping Depth
- 44.3 cm
- Shipping Height
- 13.1 cm
- Shipping Weight
- 3.7 kg
- 10 °C
- 35 °C
- 0 - 90%
