HP Scanjet Enterprise Flow 7500 Flatbed Scanner
Quicklinx: 9HDGWS00 Mfr#: L2725B#B19
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 864 mm
Interface: USB 2.0
Compatibility: PC
12 in stock
£862.40 ex VAT
£1,034.88 inc VAT
Easily integrate this legal flatbed scanner into document workflows. Get rapid scanning and reliable paper handling with HP EveryPage technology. Workgroups can enhance scans with a suite of comprehensive scan software.
  • Get fast scanning and excellent image results
    Get fast, reliable scanning – up to 50 ppm/100 ipm with 200 dpi in black-and-white, greyscale and colour.Scan up to 100 pages at a time, and choose from a variety paper types, thicknesses and sizes – up to 86 cm (34 inches) long.Scan books, ledgers, notes, cards and more using the flatbed scanner.Customize scanning profiles and easily access them, using the four-line LCD display.
  • Easily integrate and improve document management
    Simplify scanning tasks with HP Smart Document Scan Software and automatically enhance images for ideal scans.Seamlessly integrate this scanner into existing workflows using full-featured drivers.Optimize scans with built-in OCR capabilities, then save in a variety of file formats.Select from several scan-to destinations. Add metadata for easy search, archiving and sharing.
  • Count on HP reliability and save valuable time
    Scan with confidence – HP EveryPage technology keeps scan projects running smoothly.Count on dependable all-day operation with a robust scanner built to handle up to 3,000 scanned pages a day.Easily monitor the system specs and status of your scanner using HP Web Jetadmin.Take advantage of a one-year warranty and add-ons that are backed by HP's award-winning coverage.
HP ScanJet Enterprise Flow 7500 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
LED
Max Supported Document Size
216 x 864 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
50 ppm (mono) / 50 ppm (colour)
Max Document Size
216 mm x 864 mm
Automatic Duplexing
Supported Document Type
Plain paper, bulk objects (such as books, magazines and other bound materials), business card, plastic card, photo
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
3000 scans per day
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8
Microsoft Certification
Compatible with Windows 7
51.5 cm x 42.6 cm x 21.1 cm
10.61 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 864 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
CCD
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
50 ppm
Max Document Scan Speed Colour
50 ppm
Control Panel Buttons Functions
Scan, cancel, duplex, sleep, back navigation, OK/select, tools
Duty Cycle
3000 scans per day
Scanner Speed Details
100 ipm black & white (back) - A4 / Letter - 200 dpi , 100 ipm - colour - A4 / Letter - 200 dpi , 50 ppm black & white (back) - A4 / Letter - 200 dpi , 50 ppm - colour - A4 / Letter - 200 dpi , 100 ipm - greyscale - A4 / Letter - 200 dpi , 50 ppm - greyscale - A4 / Letter - 200 dpi
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 864 mm
Supported Document Size Details
ADF - up to 216 x 864 mm , Flatbed - up to Legal (216 x 356 mm)
Automatic
100 sheets
USB 2.0 - Type B
1 x USB cable
CSA, BSMI, GOST, EN 61000-3-2, EN55022, NEMKO, NOM, EN 61000-3-3, EN55024, FCC Part 15 B, CCC, KCC, IEC 60950-1 Second Edition, NRTL
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
50 Watt (15.5 Watt)
Software Included
Drivers & Utilities, Readiris Pro, Kofax VirtualReScan Professional, Nuance PaperPort, HP Smart Document Scan Software
System Requirements Details
Windows XP/7/8 - 1.3 GHz - RAM 1 GB - HD 300 MB , Windows XP - 1.3 GHz - RAM 512 MB - HD 300 MB
51.5 cm
42.6 cm
21.1 cm
10.61 kg
Shipping Width
60.7 cm
Shipping Depth
50.7 cm
Shipping Height
34.2 cm
Shipping Weight
13.5 kg
10 °C
35 °C
15 - 80%
Interface: USB 2.0
Compatibility: PC
Brand: HP
Price Range Ex VAT: 750 - 1000
