Easily integrate this legal flatbed scanner into document workflows. Get rapid scanning and reliable paper handling with HP EveryPage technology. Workgroups can enhance scans with a suite of comprehensive scan software.
Get fast scanning and excellent image results
Get fast, reliable scanning – up to 50 ppm/100 ipm with 200 dpi in black-and-white, greyscale and colour.Scan up to 100 pages at a time, and choose from a variety paper types, thicknesses and sizes – up to 86 cm (34 inches) long.Scan books, ledgers, notes, cards and more using the flatbed scanner.Customize scanning profiles and easily access them, using the four-line LCD display. -
Easily integrate and improve document management
Simplify scanning tasks with HP Smart Document Scan Software and automatically enhance images for ideal scans.Seamlessly integrate this scanner into existing workflows using full-featured drivers.Optimize scans with built-in OCR capabilities, then save in a variety of file formats.Select from several scan-to destinations. Add metadata for easy search, archiving and sharing. -
Count on HP reliability and save valuable time
Scan with confidence – HP EveryPage technology keeps scan projects running smoothly.Count on dependable all-day operation with a robust scanner built to handle up to 3,000 scanned pages a day.Easily monitor the system specs and status of your scanner using HP Web Jetadmin.Take advantage of a one-year warranty and add-ons that are backed by HP's award-winning coverage.
- HP ScanJet Enterprise Flow 7500 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Light Source
- LED
- Max Supported Document Size
- 216 x 864 mm
- Localisation
- English, German, French, Italian, Spanish / Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 50 ppm (mono) / 50 ppm (colour)
- Max Document Size
- 216 mm x 864 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, bulk objects (such as books, magazines and other bound materials), business card, plastic card, photo
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 100 sheets
- Duty Cycle
- 3000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8
- Microsoft Certification
- Compatible with Windows 7
- 51.5 cm x 42.6 cm x 21.1 cm
- 10.61 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 864 mm
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- CCD
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 50 ppm
- Max Document Scan Speed Colour
- 50 ppm
- Control Panel Buttons Functions
- Scan, cancel, duplex, sleep, back navigation, OK/select, tools
- Duty Cycle
- Scanner Speed Details
- 100 ipm black & white (back) - A4 / Letter - 200 dpi , 100 ipm - colour - A4 / Letter - 200 dpi , 50 ppm black & white (back) - A4 / Letter - 200 dpi , 50 ppm - colour - A4 / Letter - 200 dpi , 100 ipm - greyscale - A4 / Letter - 200 dpi , 50 ppm - greyscale - A4 / Letter - 200 dpi
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 864 mm
- Supported Document Size Details
- ADF - up to 216 x 864 mm , Flatbed - up to Legal (216 x 356 mm)
- Automatic
- 100 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- CSA, BSMI, GOST, EN 61000-3-2, EN55022, NEMKO, NOM, EN 61000-3-3, EN55024, FCC Part 15 B, CCC, KCC, IEC 60950-1 Second Edition, NRTL
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 50 watt (15.5 watt)
- Software Included
- Drivers & Utilities, Readiris Pro, Kofax VirtualReScan Professional, Nuance PaperPort, HP Smart Document Scan Software
- OS Required
- System Requirements Details
- Windows XP/7/8 - 1.3 GHz - RAM 1 GB - HD 300 MB , Windows XP - 1.3 GHz - RAM 512 MB - HD 300 MB
- 51.5 cm
- 42.6 cm
- 21.1 cm
- 10.61 kg
- Shipping Width
- 60.7 cm
- Shipping Depth
- 50.7 cm
- Shipping Height
- 34.2 cm
- Shipping Weight
- 13.5 kg
- 10 °C
- 35 °C
- 15 - 80%
HP Care Pack Next Day Exchange Hardware Support extended service agreement 3 years shipment | In Stock | £325.47 |
HP Scanjet ADF Roller Replacement Kit | In Stock | £53.84 |
