HP ScanJet Enterprise Flow 7000 s3 Sheet-feed Scanner - document scanner
Quicklinx: CJ2XWS00 Mfr#: L2757A#B19
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 3100 mm
Interface: USB 2.0, USB 3.0
Compatibility: PC
£698.51 ex VAT
£838.21 inc VAT
Give the office high-volume scanning performance. Easily download software – including Kofax VRS 5.1 Professional – that helps you save time and capture confidently. Achieve scan speeds up to 75 ppm/150 ipm. Recommended for 7,500 pages per day.
Fast, smooth scanning – even unattended
Capture entire documents with one-pass duplex scanning up to 150 ipm black-and-white and colour.
Peak workflow performance. Smarter scanning.
Identify new devices and gain insight into scanning with HP Web Jetadmin remote discovery and monitoring.
Professional-grade scanning that helps save time
Save time and simplify complex scan jobs with HP Smart Document Scan Software.
HP ScanJet Enterprise Flow 7000 s3 Sheet-feed Scanner - document scanner - desktop - USB 3.0, USB 2.0
Document scanner - desktop
Interface Type
USB 3.0, USB 2.0
Additional Functions
Email, fax
Max Supported Document Size
216 x 3100 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
75 ppm (mono)
Max Document Size
216 mm x 3100 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
7500 scans per day
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 3.0, USB 2.0
Email, fax
216 x 3100 mm
Scanner
Input Type
Colour Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
75 ppm
Duty Cycle
7500 scans per day
Scanner Speed Details
75 ppm - black & white - 300 dpi , 150 ipm - black & white - 300 dpi , 5.98 sec/scan - colour - 10x15cm - 200 dpi
Scanner Features
HP EveryPage
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 3100 mm
Supported Document Size Details
ADF
Automatic
80 sheets
Interfaces Details
USB 2.0 , USB 3.0
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Shipping Width
39.7 cm
Shipping Depth
30.3 cm
Shipping Height
24.8 cm
Shipping Weight
5.4 kg
CJ2X HP Electronic HP Care Pack Next Day Exchange Hardware Support - 3 years In Stock £219.17
Interface: USB 2.0
Interface: USB 3.0
Compatibility: PC
Brand: HP
Price Range Ex VAT: £500 - £750
