Abandon paper-based workflows. Advance office efficiency with fast, intuitive scanning that turns hard copies into useful digital data. Rely on clear, legible results from a compact scanner designed to enhance collaboration.
Transform paper into business flow
Send scanned files where you need them – directly to cloud storage or SharePoint .File size matters – ensure files are saved with size in mind – automatically compress large files.Straighten out your paper shuffle – transform hard copies into easy-to-use files.Look sharp by producing clear, legible scans at up to 600-dpi resolution. -
Simple scanning – ready, set, go
Save time and simplify complex scan jobs with HP Smart Document Scan Software.Fits in around the office – preserve workspace with a compact scanner designed to fit your floor plan.Create one-touch scanning efficiency by assigning your favourite settings to a single button.IT time and effort, saved – simplify deployments, installations, and event alerts. -
Page-by-page confidence
Accurately capture the right content, using auto-scan mode, crop, and colour detection.Full speed ahead – breeze through sheet after sheet at speeds of up to 30 pages and 60 images per minute.Count on this workhorse to deliver again and again with a design that can handle up to 4,000 pages per day.Spend energy wisely – this scanner turns off automatically when it's not needed to help reduce energy costs.
- HP ScanJet Enterprise Flow 5000 s3 Sheet-feed Scanner - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- LED
- Additional Functions
- Scan to cloud
- Max Supported Document Size
- 216 x 3098 mm
- Localisation
- English, German, French, Italian, Spanish / Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 30 ppm (mono) / 30 ppm (colour)
- Max Document Size
- 216 mm x 3098 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, business card, plastic card, labels, envelope
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 4000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3 or later, Windows 8
- 31 cm x 18.24 cm x 18.38 cm
- 4.82 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- Scan to cloud
- 216 x 3098 mm
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 30 ppm
- Max Document Scan Speed Colour
- 30 ppm
- Duty Cycle
- Scanner Speed Details
- 30 ppm - black & white - 300 dpi , 30 ppm - colour - 300 dpi , 60 ipm - black & white - 300 dpi , 60 ipm - colour - 300 dpi
- Scanner Features
- Automatic Separation, Automatic Image Orientation, automatic page size detection, Auto Crop, auto power off, Auto Straighten, Ultrasonic Multi Feed Detection, HP EveryPage
- TWAIN, ISIS
Media Handling
- Max Document Size
- 216 mm x 3098 mm
- Supported Document Size Details
- ADF - up to 216 x 3098 mm
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- Included Accessories
- Cleaning cloth
- Cables Included
- 1 x USB cable
- CSA, CISPR 24, SASO, CISPR 22, EMC, IEC 60950-1, UL 60950-1 Second Edition, EN 61000-3-2:2006, EN 61000-3-3:2008, EN 60950-1:2006, EAC, EN55022:2010
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 26.4 Watt
- Software Included
- Readiris Pro, Nuance PaperPort, HP Smart Document Scan Software, Cardiris Pro
- OS Required
- System Requirements Details
- Windows Vista/7/8 - 2 GHz - RAM 2 GB - HD 177 MB (USB 2.0) , Windows XP SP3 - 1.6 GHz - RAM 1 GB - HD 177 MB (USB 2.0)
- 31 cm
- 18.24 cm
- 18.38 cm
- 4.82 kg
- Shipping Width
- 39.5 cm
- Shipping Depth
- 33.2 cm
- Shipping Height
- 29.8 cm
- Shipping Weight
- 7.3 kg
- 10 °C
- 35 °C
- 15 - 80% (non-condensing)
