High speed, unattended document scanning with duplex automatic document feeder (ADF). Get the job done quickly with scan-to-PDF simplicity and bundled NewSoft Presto! PageManager document management software. ISIS compliance included.
Get more done with automatic two-sided, multi-page scanning
Load up to 50 pages in automatic document feeder (ADF) and set them scanning. Automatic processing of double-sided documents for streamlined workflow. High unattendedness – digitise multi-page documents while you get on with business. -
Do the job faster and return to work sooner with high speed document processing
Scan up to 8 pages per minute (or 4 images per minute) using the duplex ADF. No waiting around – view preview scans in about seven seconds. Store, organise and access digitised documents using bundled NewSoft Presto! PageManager software. -
Digitise images from slides and negatives with included transparent materials adapter (TMA)
Complete out-of-the-box scanning solution – capture high quality scans from 35 mm slides and negatives. Easy plug-in connection – no need to remove the standard scanner lid. TMA can also be used as a light box for viewing/selecting slides.
- HP ScanJet 5590 Digital Flatbed Scanner - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Max Supported Document Size
- 216 x 297 mm
- Localisation
- English / United Kingdom
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 48-bit colour
- Optical Resolution
- 2400 dpi x 2400 dpi
- Interpolated Resolution
- 999999 dpi x 999999 dpi
- Max Document Size
- 216 mm x 297 mm
- Supported Document Type
- Transparencies, plain paper, slides, film
- Document Feeder Type
- Manual, automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.1.5, Apple MacOS X 10.2 or later
- Microsoft Certification
- Certified for Windows Vista
- 48.8 cm x 34 cm x 16.2 cm
- 5.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- 216 x 297 mm
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- Control Panel Buttons Functions
- Scan, copy, email, Scan-to-Web, power save, cancel, Scan-to-PDF
- Scanner Speed Details
- 28 sec/scan - photo - colour - 10x15cm , 31 sec/scan - black & white , 48 sec/scan - OCR - A4 , 7 sec/scan - preview
- TWAIN
Media Handling
- Max Document Size
- 216 mm x 297 mm
- Manual, automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- Included Accessories
- Automatic document feeder, transparency adaptor
- Cables Included
- 1 x USB cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- UL, GOST, EN 60950, PCBC, EMC
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 36 Watt
- Software Included
- Drivers & Utilities, Presto! PageManager, HP Memories Disc Creator, HP Instant Share, I.R.I.S. OCR
- OS Required
- Additional Requirements
- CD-ROM, SVGA monitor, USB port
- System Requirements Details
- Windows 98/98SE/2000/ME/XP - Pentium II RAM 64 MB - HD 225 MB , MacOS X 10.1.5 or later - RAM 128 MB - HD 240 MB
- 48.8 cm
- 34 cm
- 16.2 cm
- 5.7 kg
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 5 - 90%
Customer reviews
Write a review for the HP Scanjet 5590 here!
Unstable software
Reviewed by Paul Williamson. Review Posted 31/03/2007
I had an older version of this scanner which was, like other HP products up to then, fast, efficient and as solid as a rock. It got involved in a lightning strike so had to be replaced. This HP5590 is by comparison a waste of time, largely because of the software which has so many fgeatures it can't stand up. I'm constantly battling to stop it automatically doing things I don't want. I'm faily experienced at all this but the way this keeps failing in different ways and then works and then doesn't again has wasted hours. It has been difficult to find these features at this price until now when there is now competition. Any other scanner must be better than this. It's the software that's the problem but upgrades and re-installs fail to fix the unreliability.
Overall
Ease of use
Value for money
HP Scanjet
Reviewed by Ed Sedgwic. Review Posted 12/11/2007
The software that goes with this is way too complex. The hardware itself is fine but the hassle factor is huge. I wish I had bought something else.
Overall
Ease of use
Value for money
HP ScanJet 5590 software problems
Reviewed by Anonymous Review Posted 06/12/2007
I purchased one of these three months ago and the scanning and copying process hangs most of the time (at least 75% of the time, sometimes worse). Even after two software reinstalls it continues to fail. Base unit was replaced, but same problems occured.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
HP Scanjet 5590
