HP ScanJet 5000 Sheetfeed Scanner
HP Scanjet 5000 Sheet-feed Scanner
Quicklinx: 5KCZWS00 Mfr#: L2715A#BEA
Manage all your office scanning processes with this fast, easy-to-use business scanner. Automatically capture stacks of single or double-sided documents and streamline common tasks such as saving, filing and organising scanned images.
  • Fast document scanning for your everyday needs
    Capture documents in black, greyscale or colour at up to 25 ppm/50 ipm with this easy to use simplex/duplex scanner. Experience reliable unattended operation with 50-page automatic document feeder and handle volumes of up to 1,500 pages a day.
  • Streamline everyday scanning tasks using programmable, easy-to-access scan profiles
    Streamline processes using HP Smart Document Scan Software. Create customised scan profiles, preview and edit scanned images, save in a wide range of file formats including PDF and Microsoft Word, and send directly to email, folder or application.
  • Get started with document management today
    Create a document management solution out of the box with ScanSoft PaperPort , or integrate into an existing system using ISIS , TWAIN and WIA drivers. Convert scans into editable text with IRIS Readiris Pro OCR software.
HP ScanJet 5000 - sheetfed scanner - desktop - USB 2.0
Sheetfed scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
216 x 864 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Max Document Size
216 mm x 864 mm
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
2000 scans per day
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Media Center Edition, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista
Microsoft Certification
Certified for Windows Vista
32 cm x 28 cm x 24.6 cm
7.2 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
216 x 864 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Duty Cycle
2000 scans per day
TWAIN
Media Handling
Max Document Size
216 mm x 864 mm
Plain paper
Supported Document Size Details
ADF - up to 216 x 864 mm
Automatic
50 sheets
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ENERGY STAR Certified
Power Consumption Operational (Standby)
40 Watt
32 cm
28 cm
24.6 cm
7.2 kg
Shipping Width
49.6 cm
Shipping Depth
40 cm
Shipping Height
37.5 cm
Shipping Weight
10.2 kg
Limited warranty - express exchange - 1 year - carry-in
10 °C
35 °C
15 - 80%
