HP Quick Relase Bracket for TFT
HP LCD Monitor Quick Release Mount
Quicklinx: 4RPNWS00 Mfr#: EM870AT
A secure and easy-to-use mounting solution for your VESA-compliant HP flat panel monitors, thin clients and other HP desktop products. Attach to any a compatible stand, bracket or wall mount and make the most of your workspace.
HP Quick Release mounting kit - for LCD display / thin client
Mounting kit
Mounting Components
Quick release bracket
13.2 cm x 1.65 cm x 16 cm
370 g
Recommended Use
VESA Mounting Interface
100 x 100 mm
Max Load Weight
10.9 kg
Package Content
8 x 15.5 mm screws, 4 x 20 mm screws, 8 x 10 mm screws
1-year warranty
HP 260 G2, Elite 8300, t430, t530, t5545, t628; Chromebox G2; EliteDesk 705 G3; EliteOne 800 G1, 800 G3, 800 G5; Flexible t520, t610; ProDesk 400 G3; ProOne 400 G2, 600 G1; RP9 G1 Retail System; Smart t410; Thin Client t5730; HPE t5145, t5540; Compaq Thin Client t5735; Flexible Thin Client t510
13.2 cm
1.65 cm
16 cm
370 g
Package Content
Manufacturer Selling Program
HP Smart Buy
AV Furniture
Mounting kit
Mounting Components
Recommended Use
100 x 100 mm
Max Load Weight
10.9 kg
Dimensions & Weight Details
19.8 cm x 15.9 cm x 3.8 cm / 490 g
Limited warranty - 1 year
Compaq LA2405wg, S1921, S1922, S2021 , HP 2310ti, 260 G2, gt7720, gt7725, L1506, L1506s, L1706, L1706v, L1710, L1740, L1750, L1906, L1908w, L1908wm, L1910, L1940T, L1945w, L1945wv, L1950, L1950g, L2045w, L2105tm Touchscreen, L2208w, L2245w, L2245wg, L2445w, LA1905wg, LE1851w, LE1901w, LE1901wm, LE2001w, LE2001wm, LE2201w, S1932, S1933, S2021, S2031, S2032, S2231a, S2331a, t430, t530, t5325, t5545, t5550, t5565, t5570, t5630, t5630w, t5740, t5740e, t5745, t628, v185w, v185ws, v216w, vc4820T, vc4825T, w17e, ZR30w , HP Chromebox G2 , HP EliteDesk 705 G3 (mini desktop) , HP EliteOne 800 G1, 800 G3, 800 G5 , HP Flexible t520, t610, t610 PLUS , HP ProDesk 400 G3 , HP ProOne 400 G2, 600 G1 , HP RP9 G1 Retail System 9118 , HP Smart t410 , HP Streaming Client st5548, st5738, st5742, st5747, st5748 , HP Compaq 6005 Pro (ultra-slim desktop), 6300 Pro PC, Elite 8300 PC, L2105tm, LA1751g, LA1905wg, LA1951G, LA2205wg, LA22f, LA2405wg, LE1711, LE1911, LE19f, s1922, S2021 , HP Compaq Business Desktop dx2009 , HP Compaq Thin Client t5135, t5530, t5720, t5725, t5730, t5730w , HPE t5145, t5540 , HPE Compaq Thin Client t5735 , HPE Flexible Thin Client t510
