HP ProOne 600 G1 21.5" All-in-One Intel Core i5-4570S 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BBW5WS00 Mfr#: H5T94EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Core i5
Design, productivity, and security. All in one. Set a new pace for your office productivity while demanding less from your IT team. Take on work more efficiently with a sleek PC designed to free your desk from clutter. Count on powerful built-in software that enhances security, manages updates, and automates backups. Your boss will praise you. Your IT staff will thank you.
  • Keep everything in sight
    Watch your inbox while working on other tasks. There's plenty of screen room for all of your work with optional support for up to four external displays.Make the most of virtual conferencing. Bring work to life through immersive surround sound with deep, rich bass and crystal clear dialog using DTS Studio+ and an optional HD Webcam.
  • Hassle-free security
    HP Client Security suite helps you quickly and easily encrypt your hard drive, permanently delete unwanted or discarded data, restrict unauthorized access, and more.No more remembering passwords. HP Password Manager lets you quickly log in to various online accounts. Now your passwords can be longer and more secure.
  • Do more by reclaiming your workspace
    Stay organized and free up more room for work. This space-saving all-in-one has several stand options, and easily mounts on the wall.
  • The hub of your mobile world
    Speed up charging with a fast charging USB port. The nearly 2.8x stronger charging current helps compatible devices charge faster than standard USB 3.0 ports.Easily share your internet connection with your devices and help colleagues get online fast with HP Wireless Hotspot.Maintain tighter control over device security. Use the optional integrated near-field communications (NFC) capabilities to support custom applications such as advanced user authentication.
  • Fast-track your performance
    Quickly open new files and switch applications with less wait time thanks to solid-state drives and solid-state hybrid drive options. Get the latest processing technology with a choice of 4th generation Intel Core processors.Make better use of your workspace. HP ePrint makes wireless printing simple-no need for drivers.Get the team together. This Microsoft Lync qualified all-in-one is designed for productive virtual meetings with team members near and far.
  • Plan with confidence
    Get more out of your investment. The HP ProOne 600 G1 is designed for a long lifecycle, with platform stability up to 30 months.HP ProOne PCs are rigorously tested to help ensure reliability. During the HP Total Test Process, our PCs experience 115,000 hours of performance trials to help get you through your business day.Spend less time managing updates with HP Support Assistant. You can also safeguard your data with easy backup and recovery, using HP Recovery Manager.
HP ProOne 600 G1 - all-in-one - Core i5 4570S 2.9 GHz - 4 GB - 500 GB - LED 21.5"
Personal computer - all-in-one
1 x Intel Core i5 (4th Gen) 4570S / 2.9 GHz (3.6 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Monitor
21.5" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
Intel HD Graphics 4600 Dynamic Video Memory Technology
Audio Output
Integrated
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
52.19 cm x 19.56 cm x 42.68 cm
8.8 kg
Environmental Standards
TCO Certified ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
All-in-one
Processor / Chipset
CPU
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q85 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total)
Unbuffered, dual channel memory architecture
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
LED - IPS
Diagonal Size
21.5"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Pixel Pitch
0.248 mm
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, 72% colour gamut
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Audio Output
Integrated
Max Sampling Rate
192 kHz
DTS SOUND+
Speakers Included
2 x right / left channel
Input Device
Mouse, keyboard
Keyboard
USB
Ethernet Controller
Intel I217-LM
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2x2.5" / 1x3.5" shared
Slots
1 (total) / 1 (free) x PCIe Half Mini Card , 1 (total) / 1 (free) x MXM 3.0 Type A , 1 (total) / 0 (free) x CPU , 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x mSATA
4 x USB 3.0 , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x microphone , 1 x headphones , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort
USB port control, chassis intrusion detection, HP File Sanitizer
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
CSA, UL, CCC, FCC, Energy-using Products (EuP) Lot 6, CECP
TAA Compliant
Power supply
Nominal Voltage
Power Provided
180 Watt
80 PLUS Certification
80 PLUS
Efficiency
91%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
Software
Cyberlink PowerDVD, CyberLink PowerDirector, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, PDF Complete, HP Support Assistant, Bing Toolbar, EverNote, HP ePrint, CyberLink Media Suite, Drive Encryption for HP ProtectTools, Microsoft Internet Explorer 10, CyberLink PhotoDirector, Device Access Manager, HP Page Lift, HP File Sanitizer, HP Disk Sanitiser (free download)
ENERGY STAR Certified
52.19 cm
19.56 cm
42.68 cm
8.8 kg
10 °C
35 °C
10 - 90% (non-condensing)
