Raise your HP ProOne 400 PC off the desk or counter in single-and multi-user environments and enable adjustable comfort features with the HP ProOne 400 Recline and Height Adjustable Stand.
Get comfortable
Find your best position for viewing and interacting with the screen with adjustable height, tilt, and recline settings. -
Assemble in a snap
Simply attach an HP ProOne 400 to the VESA mount on the Stand and secure with the included captive screws. -
Keep working
Retain easy access to your HP ProOne 400's ports and inputs.
- HP Height Adjustable Stand mounting kit - for All-In-One
- Product Type
- Mounting kit
- Mounting Components
- Stand base
- 40.29 cm x 26.74 cm x 24.77 cm
- 7.5 kg
- Recommended Use
- All-In-One
- Designed For
- ProOne 400 G1
- 40.29 cm
- 26.74 cm
- 24.77 cm
- 7.5 kg
AV Furniture
- Mounting kit
- Stand base
- Recommended Use
- All-In-One
- Designed For
- HP ProOne 400 G1
