Ready for versatile work environments
Easy to deploy, sleek, and feature-rich, the HP ProOne 400 20 All-in-One PC features a contemporary design with business-class performance, collaboration, security, and manageability features.
Functionality for the multi-device world
Provide users with multiple devices options for how they work and stay productive. New flexibility is delivered by the HP ProOne 400 20 AiO that can be used as a full PC or as an additional display for another desktop or laptop PC
HP exclusive security and manageability
Help prevent data breaches and downtime with HP Sure Sense4, HP Sure Click5, and HP BIOSphere Gen5.6 Simplify management with the HP Manageability Integration Kit.
Powerful options
Choose a high-performance 10th Gen Intel® Core™ processor2, powerful memory, and graphics
Provide users with multiple devices options for how they work and stay productive. -
Sleek, elegant design
Stylish design and clean lines make this AiO suitable for a front desk or space-constrained work environments.
- HP ProOne 400 G6 - all-in-one Core i5 10500T 2.3 GHz - 8 GB - SSD 256 GB - LED 19.53" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i5 (10th Gen) 10500T / 2.3 GHz (up to 3.8 GHz, (6-core)
- Processor Main Features
- Intel Turbo Boost Technology
- Cache Memory
- 12 MB
- Cache Per Processor
- 12 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA/NVMe
- Hard Drive
- SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- DVD-Writer
- Card Reader
- Monitor
- 19.53" - LED - 1920 x 1080 (Full HD) @ 60 Hz - 16:9
- Graphics Controller
- Intel UHD Graphics 630 Dynamic Video Memory Technology
- Camera
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.1, Wi-Fi 6
- Keyboard
- UK
- Power
- (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition National Academic
- Software Included
- HP Support Assistant, HP Hotkey Support, Windows Defender, HP Secure Erase, HP BIOS Config Utility, HP Setup Integrated OOBE, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense, HP Client Security Manager Gen6, HP Manageability Integration Kit Gen4, HP BIOSphere Gen6, HP Image Assistant Gen5
- 47.2 cm x 5.07 cm x 31.6 cm
- 4.74 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- All-in-one - with Fixed Height Tilt Stand
- Built-in Devices
- Dual 2 W speakers
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel Q470
Cache Memory
- Installed Size
- 12 MB
- 12 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA/NVMe
Optical Storage
- DVD-Writer - SATA
Card Reader
- Card reader
Monitor
- Monitor Type
- LED - VA
- Diagonal Size
- 19.53"
- Native Resolution
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Gamut
- 72% NTSC
- Response Time
- 25 ms
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 3000:1
- Monitor Features
- Anti-glare, 72% NTSC colour gamut
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Max Sampling Rate
- 192 kHz
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution
- HD
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
Audio Input
- Dual array microphone
- Interface (Bus) Type
- M.2 Card
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wi-Fi 6 AX 201
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.1, IEEE 802.11ax (Wi-Fi 6)
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), auto-uplink (auto MDI/MDI-X), PXE 2.1 support, dual stream (2x2)
- Bays
- 1 (total) / 1 (free) x internal 2.5" , 1 (total) / 0 (free) x external 5.25" Slim Line
- Slots
- 1 (total) / 0 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2230/2280
- 1 x USB-C 3.2 Gen 2 (1 side) , 4 x USB 3.2 Gen 1 , 1 x DisplayPort 1.4 , 1 x headphones/microphone (1 side) (CTIA and OMTP headset support) , 1 x LAN (Gigabit Ethernet) , 1 x HDMI input , 1 x USB 3.2 Gen 2 (1 side) , 1 x HDMI
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, Common Criteria EAL4+, low halogen
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Provided
- 90 watt
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition National Academic English
- Software
Sustainability Information
- ENERGY STAR Certified
- Dimensions & Weight Details
- 47.2 cm - 5.07 cm - 31.6 cm - 4.74 kg - without stand , 47.2 cm - 15.65 cm - 36.61 cm - 5.46 kg - with stand
- 47.2 cm
- 5.07 cm
- 31.6 cm
- 4.74 kg
- Shipping Width
- 59.5 cm
- Shipping Depth
- 24.5 cm
- Shipping Height
- 41.4 cm
- Shipping Weight
- 8.16 kg
- 5 °C
- 35 °C
- 5 - 90% (non-condensing)
