HP ProOne 400 G4 Core i5-8500T 8GB 1TB All-In-One 20" Windows 10 Pro
Quicklinx: DV9LWS00 Mfr#: 4NT83EA#ABU
  • Core i5
  • IEEE 802.11n
Easy to deploy, sleek, and feature-rich, the HP ProOne 400 20" All-in-One PC features a contemporary design with business-class performance, collaboration, security, and manageability features.
  • Let nothing stand in your way
    Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day.
  • Expansion that extends your investment
    Maximize the life of your PC as your business requirements change with options that let you expand on your own schedule, including M.2 drives, SATA drives, and up to 32GB of DDR4 memory.
  • Work without interruption
    Keep productivity high and downtime low with HP BIOSphere Gen4 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.
  • Super secure. Super protected
    Guard your data, device and identity with HP Client Security Manager Gen4.
  • Browse confidently
    Help protect your PC from websites, attachments, malware, ransomware, and viruses with hardware-enforced security from HP Sure Click.
  • Speed up the basics of IT management
    The HP Manageability Integration Kit Gen2 helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
HP ProOne 400 G4 - all-in-one - Core i5 8500T 2.1 GHz - 8 GB - HDD 1 TB - LED 20" - UK
Personal computer - all-in-one
Intel Core i5 (8th Gen) 8500T / 2.1 GHz (, up to 3.5 GHz, (6-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
4 in 1
Monitor
20" - LED - 1600 x 900 (HD+) - 16:9
Graphics Controller
Intel UHD Graphics 630
Camera
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
48.91 cm x 5.13 cm x 32.4 cm
3.9 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Hood sensor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q370
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer
Card Reader
4 in 1 card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
LED - TN
Diagonal Size
20"
Native Resolution
1600 x 900 (HD+)
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Colour Gamut
72% NTSC
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, 72% NTSC colour gamut
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Max Sampling Rate
192 kHz
High Definition Audio
Speakers
Bang & Olufsen sound bar
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
1 Megapixel
Resolution
HD
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Audio Input
Microphone
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
Wake on LAN (WoL), ACPI support, PXE 2.1 support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 5.0
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x external , 1 (total) / 0 (free) x internal 2.5"
1 x USB-C , 4 x USB 3.1 Gen 1 (2 rear) (one of them is charging) , 1 x DisplayPort , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE
Power adapter
Efficiency
89% (115VAC), 89% (230VAC)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Dimensions & Weight Details
48.91 cm - 5.13 cm - 32.4 cm - 3.9 kg - without stand
48.91 cm
5.13 cm
32.4 cm
3.9 kg
5 °C
35 °C
5 - 90%
Warranties (7)
DV9L HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £30.97
DV9L HP Care Pack Extended Service Agreement Next Business Day 2 Years In Stock £65.90
DV9L HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £16.46
DV9L HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £56.53
DV9L HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £7.06
DV9L HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £73.49
DV9L HP 3 Year Premium Care Desktop In Stock £99.60
Other bundles (1)
DV9L HPE DisplayPort to VGA Adapter In Stock £13.20
