Easy-to-deploy, sleek, and feature-rich, the HP ProOne 400 20" All-in-One PC with business-class collaboration and security features is a sound investment.
Let nothing stand in your way
Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ProOne 400 AiO. -
Super secure. Super protected
Guard your data, device and identity with HP Client Security Suite Gen3. -
Work without interruption
Keep productivity high and downtime low with HP BIOSphereGen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks. -
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager. -
Several deployment options
Pair this space-saving AiO with the mounting option to fit your workspace and use case. -
Cut out the chatter
Suppress background noise including keyboard clicks with HP Noise Cancellation Software.
- HP ProOne 400 G3 - all-in-one Core i5 7500T 2.7 GHz - 8 GB - HDD 1 TB - LED 20" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i5 (7th Gen) 7500T / 2.7 GHz (up to 3.3 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Monitor
- 20" - LED - 1600 x 900 (HD+) - 16:9
- Graphics Controller
- Intel HD Graphics 630 Dynamic Video Memory Technology
- Camera
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP JumpStart, HP Noise Cancellation, HP BIOSphere Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Notifications, HP Driver Packs (free download)
- 49.772 cm x 5.889 cm x 34.751 cm
- 5.61 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- All-in-one - with height-adjustable stand
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel H270
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- LED - TN
- Diagonal Size
- 20"
- Native Resolution
- 1600 x 900 (HD+)
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Colour Gamut
- 72%
- Pixel Pitch
- 0.276 mm
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 1 Megapixel
- Resolution
- 1280 x 720
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
Audio Input
- Two microphones
- Data Link Protocol
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2230/2280 (x4 mode)
- 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 2 x USB 2.0 , 1 x DisplayPort , 1 x headphones , 1 x microphone , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, Common Criteria EAL4+, low halogen
- Power adapter
- Voltage Required
- Power Provided
- 90 Watt
- Efficiency
- 89%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- Dimensions & Weight Details
- 49.772 cm - 5.889 cm - 34.751 cm - 5.61 kg - without stand
- 49.772 cm
- 5.889 cm
- 34.751 cm
- 5.61 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
Warranties (1)
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £16.46 |
Other bundles (2)
HPE DisplayPort DVI-D Adapter | In Stock | £11.55 |
HPE DisplayPort to VGA Adapter | In Stock | £13.38 |
