HP Promo Z240 MT Intel Core i7-6700 8GB 1TB HDD Windows 7 Professional (64-bit)
Quicklinx: C7Z8WS00 Mfr#: J9C16ET#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
HP's entry level workstations just got better. The HP Z240 with two amazingly versatile form factors, packs the performance, features, and reliability of a workstation into the price point of a desktop PC.
  • Choose the OS for you
    Support your unique user needs with a choice of Windows 10 Pro or Linux operating systems.
  • Better Package. Bigger Punch
    Get more performance, expandability and flexibility in the chassis the world loves.
  • Powerful performance
    Achieve the performance you need with your choice of next generation Intel Xeon processors or Intel Core processors.
  • Ultra-fast storage
    Handle large files, reduce work time and increase performance with the optional HP Z Turbo Drive.
  • Work smarter
    Up to 64 GB DDR4 ECC memory helps provide no compromise capacity, performance, and reliability.
  • Geared up graphics
    Ignite productivity with NVIDIA professional graphics cards in 2D or 3D.
HP Workstation Z240 - MT - Core i7 6700 3.4 GHz - vPro - 8 GB - HDD 1 TB - UK
Workstation - mini tower
Platform Technology
Intel vPro Platform
1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz (, up to 4 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 530
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
17 cm x 44.2 cm x 39.9 cm
8.6 kg
Manufacturer Selling Program
HP Smart Buy
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mini tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 64 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
RAM Supported
64 GB unbuffered - ECC , 64 GB unbuffered - non-ECC
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Max Monitors Supported
3
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Laser
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
2 (total) / 2 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x internal 2.5" x 1/8H
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x1 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height , 1 (total) / 1 (free) x M.2 Card (x4 mode)
6 x USB 3.0 (2 front, 4 rear) , 4 x USB 2.0 (2 front, 2 rear) , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 2 x DisplayPort , 1 x DVI-I , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 4.0
HP Smart Buy
Power supply
Power Provided
400 Watt
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
17 cm
44.2 cm
39.9 cm
8.6 kg
5 °C
35 °C
8 - 85% (non-condensing)
