HP ProLiant Moonshot Intel Atom S1260 8GB NO HDD
Quicklinx: 9NVPWS00 Mfr#: 700352-B21
  • Atom
  • Red Hat Enterprise Linux
As a dedicated hosting company are you using large numbers of traditionally architected servers? Are you hitting the wall for power, cooling and space? The HP ProLiant Moonshot Server uses an innovative new architecture that results from one simple design tenet: to align purpose-built solution Servers with the right workload to provide optimal results for your dedicated hosting environment. Traditional servers rely on dedicated components, including management, networking, storage, power cords and cooling fans in a single chassis. In contrast, the Moonshot Server shares these chassis components that are capable of supporting 45 servers per 4.3U chassis. This gives you the ability to generate greater revenue from a smaller footprint while driving down your operational costs. The ProLiant Moonshot Servers use low-energy processors and direct attached disk drives to provide an ideal solution for dedicated hosting.
  • Achieve Breakthrough Efficiencies in Density, Energy, and Cost
    The HPE Moonshot 1500 Chassis has 45 hot-pluggable servers installed and fits into 4.3U. The density comes in part from the low-energy, efficient processors. The innovative chassis design supports 45 servers, 2 network switches, and supporting components.This shared, federated approach saves energy and cost. But just as importantly, it enables extreme scale-out without a corresponding increase in complexity and management overhead. Network fabric is integrated into the system and shared to reduce cabling.To increase efficiency, every component above the processor level-elements including power, network fabric, and HPE Integrated Lights Out (iLO) management-is pulled into the chassis to be shared among all the servers. This saves both power and cooling costs.
  • Simplified Infrastructure and Management at Extreme Scale in the Data Center
    In the past adding a server meant more devices-power, I/O devices, network controllers, device drivers-to be managed, powered, and cooled. HPE Moonshot introduces a new level of sharing by integrating resources across the system which means you can scale farther, faster than before.The iLO processors are networked together in the iLO chassis manager to control the complete HPE Moonshot system. These processors share health reporting and management activities for all the servers in the chassis while monitoring the network switches and chassis.For effective power management, the management framework is at the chassis level, enabling the federated chassis management to operate as a single management point for an entire rack or row of racks.The Advanced Power Manager provides a rack-level solution that enables chassis-level power on and off, chassis-metering, Rack Dynamic Power Capping, and asset management capabilities for HPE ProLiant Moonshot Server.
  • Enables New Tiers of Hosted Services
    The HPE ProLiant Moonshot Server aligns specific architectures with the right workload to provide an optimally tuned solution. Hosting companies can deploy an architecture for the actual workloads, removing inefficiencies in density, energy, and cost to allow for more competitive offerings.The simplicity of purchasing a complete system with compute, networking, and management fits the rapid deployment requirements of the demanding dedicated hosting environment.
HPE ProLiant Moonshot Server - cartridge - Atom S1260 2 GHz - 8 GB - no HDD
Server - cartridge
Server Scalability
1-way
1 x Intel Atom S1260 / 2 GHz (Dual-Core)
Cache Memory
1 MB
Cache Per Processor
1 MB
RAM
8 GB (installed) / 8 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-10600
Storage Controller
SATA (SATA 6Gb/s) - PCIe 2.0 (Marvell 9125)
Hard Drive
No HDD
Optical Storage
No optical drive
GigE
Server
Recommended Use
Small business, corporate business
Product Form Factor
Cartridge
Server Scalability
1-way
Internal Bays Qty
1
Processor / Chipset
CPU
Intel Atom S1260
Clock Speed
2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
1 MB
Cache Per Processor
1 MB
RAM
Installed Size
8 GB / 8 GB (max)
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
SO-DIMM 204-pin
Slots
1 (Total) / 0 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated - PCIe 2.0
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Marvell 9125
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720
PXE support
IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x internal 2.5" SFF
Slots
1 (total) / 0 (free) x SO-DIMM 204-pin
ACPI 2.0b, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Red Hat Enterprise Linux
10 °C
35 °C
10 - 90% (non-condensing)
