HP ProLiant ML370 G6 Quad Core Xeon E5520 4GB DVD
Quicklinx: 62RNWS00 Mfr#: 487795-031
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-ROM
The HP ProLiant ML370 G6 provides dual processor compute power in a convenient, 4U expandable tower chassis designed for businesses who want enterprise class features and performance. The HP ProLiant ML370 G6 has been optimized for virtualization and consolidation environments, it is well-suited for deployment in growing businesses, remote office sites, or data centers.
  • Manage Seamlessly From Anywhere, Anytime
    The new HPE ProLiant Onboard Administrator (powered by the HPE Integrated Lights-Out 2 management processor) and the HPE Systems Insight Manager allow you to manage the HPE ProLiant ML370 G6 seamlessly, from anywhere, anytime.Configuration is quick and consistent with the HPE ProLiant portfolio of deployment tools, such as SmartStart, Pre-Boot Execution Environment (PXE), Array Configuration Utility (ACU), and ROM-Based Setup Utility (RBSU).
  • Optimize System Performance and Ease of Serviceability
    Intel Xeon processors 5600 and 5500 series offer higher performance, better power efficiency, and more adaptability with Intel QuickPath, Integrated Memory Controller, Turbo Boost, and Intelligent Power Technologies.Up to 192 GB Registered Memory DIMMS (up to 48 GB Unbuffered). Memory intensive applications benefit from higher memory footprint (18 DIMM slots), Advanced ECC, Online Spare mode and Mirrored memory.Nine (9) available PCI-Express Gen2 expansion slots provide latest I/O performance.Clean, tool-free, mechanical design enhances reliability and simplifies configuration and maintenance with tool-free, modular components, hot plug redundancy features for fast maintenance, and minimal cables for easy access to components.Commonality focus, increases IT productivity with universal drives, Smart Array Controllers, and power supplies, common components simplify spares.
  • Maximum Expandability and Flexibility
    Expandable storage support of up to 24 small form factor (SFF) or 14 large form factor (LFF) hot-plug drive bays to support Serial-attached SCSI (SAS) and Serial ATA (SATA) drives.Up to 192 GB Registered Memory DIMMS (up to 48 GB Unbuffered). Memory intensive applications benefit from higher memory footprint (18 DIMM slots), Advanced ECC, Online Spare mode and Mirrored memory.Nine (9) available PCI-Express Gen2 expansion slots provide latest I/O performance.
  • Energy Efficiency Leadership
    Delivering more power for your needs with the highest efficiency in the industry, as seen by meeting Climate Savers Computing Gold, 80PLUS Gold, and setting the standards for Energy Star for Servers compliance.Right-Sized ProLiant Power Supplies from 460Watts at 92% efficiency, 750 Watts at 92% efficiency, to 1200 Watts at 90% efficiency. Be sure to use the HPE Power Advisor for selecting the right size power supply."Intelligent Power & Cooling Savers" Smart power stops power delivery when components are not in use, adjusting fan control for efficient cooling. Smart Sensors allow intelligent actions to preserve, protect and enhance performance and power savings.Improve your capacity up to 3x with Dynamic Power Capping and Insight Power Manager. Dynamic Power Capping allows you to cap the servers power use level, without impacting performance and still fully protecting the Circuit Breakers.
HPE ProLiant ML370 G6 - tower - Xeon E5520 2.26 GHz - 4 GB - no HDD
Server - tower - administrator password, power-on password, keyboard password, disk configuration lock, diskette I/O control, parallel port I/O control, serial port I/O control, quick lock
Height (Rack Units)
4U
Server Scalability
2-way
1 x Intel Xeon E5520 / 2.26 GHz (2.53 GHz) (Quad-Core)
Processor Main Features
Hyper-Threading Technology
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
4 GB (installed) / 192 GB (max) - DDR3 SDRAM - PC3-8500
Storage Controller
RAID (SATA 1.5Gb/s / SAS) - PCIe x8 (Smart Array P410i); IDE
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD
Video Memory
64 MB
GigE
Windows Server Certified
This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
47 cm x 74 cm x 24.8 cm
30 kg
Limited warranty - parts and labour - 3 years - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Tower - 4U
Server Scalability
2-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Intel Xeon E5520
Clock Speed
2.26 GHz
Max Turbo Speed
2.53 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel 5520
Front Side Bus
1066 MHz
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
4 GB / 192 GB (max)
DDR3 SDRAM
Effective Memory Speed
800 MHz
Rated Memory Speed
1066 MHz
Memory Specification Compliance
PC3-8500
DIMM 240-pin
Slots
18 (Total) / 16 (empty)
Registered
Configuration Features
2 x 2 GB
RAM Supported
PC3-8500 - 192 GB registered , PC3-10600 - 48 GB unbuffered
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card - PCIe x8
Controller Interface Type
SATA 1.5Gb/s / SAS
Storage Controller Name
Smart Array P410i
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 0+1, RAID 0+5
Storage Controller (2nd)
1 x IDE - integrated
Optical Storage
DVD-ROM DVD - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Memory
64 MB
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP NC375i
Remote Management Controller
Integrated Lights-Out 2 Standard
Wake on LAN (WoL)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
Bays
3 (total) / 2 (free) x external 5.25" x 1/2H , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
7 (total) / 6 (free) x PCIe x8 , 3 (total) / 3 (free) x PCIe x16 , 18 (total) / 16 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x VGA , 5 x USB , 4 x LAN (Gigabit Ethernet) , 1 x management
Administrator password, power-on password, keyboard password, disk configuration lock, diskette I/O control, parallel port I/O control, serial port I/O control, quick lock
ACPI 2.0
Power supply - hot-plug
Power Provided
460 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, SunSoft Solaris x86 10
47 cm
74 cm
24.8 cm
30 kg
10 °C
35 °C
10 - 90%
