HP ProLiant ML110 G7 2 GB RAM 2.8 GHz
Quicklinx: 7XCHWS00 Mfr#: 470065-612
  • Pentium
  • Red Hat Enterprise Linux
  • DVD-ROM
The HP ProLiant ML110 G7 is the perfect first server for a growing business. It provides an affordable, efficient, functional solution to small/medium businesses that are budget-conscious and have basic or no in-house IT resources. With proven ProLiant reliability, support for the latest Intel Xeon , Core i3, Pentium and Celeron processors, an optional redundant power supply (RPS), and two NICs, the ML110 G7 provides the ideal solution for the expanding business. A mix of PCI-Express slots, DIMM slots, drive bays, and server options delivers the expandability needed. Integrated iLO3 remote management drives down the operational costs by reducing the number of physical visits. An HP Smart Start CD enhances the installation process. Optional TPM provides an additional level of security, and a high efficiency power supply is available to further reduce power consumption.
  • Proven HPE Dependability and Support
    HPE has built a reputation of dependability by conducting some of the most rigorous and thorough testing in the industry.ProLiant quality starts with design and is optimized in manufacturing.Tireless work on system testing and process control ensures only the most dependable products for the customers.Worldwide network of HPE trained service professionals.
  • Easy to Expand and Grow with Changing Business Needs
    This powerful, yet simple platform, provides all the relevant server features in an easy-to-use and easy-to-afford package.Two NICs, up to eight SFF HDDs, 10 USB ports, and four PCIe 2.0 slots give the ML110 G7 plenty of headroom to grow with your business.The modular design of ML110 G7 requires less upfront investment and allows for expandability as needed. All major components are designed to be removed or installed with minimal effort.Companies with remote locations or branch offices can take advantage of the integrated iLO3 remote management to decrease server/company downtime and increase productivity.Rack mountable for space savings.
  • A True Server at a Desktop Price
    Incorporates features for small/medium businesses and remote site locations.The focus on design provides a flexible server for low cost expansion.Improved processor and memory performance along with the support for efficient power supply reduce overall operational costs.iLO3 remote management drives down the cost of managing the servers by reducing visits while decreasing the need for multiple remote management solutions.
  • Proven ProLiant Reliability and Data Protection
    ECC memory protects businesses from data loss and unplanned system downtime.Smart Array options provide businesses RAID mirroring and striping capability to protect critical data.iLO3 remote management decreases server downtime.Trusted Platform Module provides an option for advance data security with hardware-based encryption and authentication.Redundant PSU for more security and essential productivity backup.
HPE ProLiant ML110 G7 - micro tower - Pentium G840 2.8 GHz - 2 GB - HDD 250 GB
Server - micro tower - system password, power-on password
Height (Rack Units)
4U
Server Scalability
1-way
1 x Intel Pentium G840 / 2.8 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
2 GB (installed) / 16 GB (max) - DDR3 SDRAM - ECC - PC3-10600
Storage Controller
SATA (SATA 3Gb/s) (Smart Array B110i)
Hard Drive
HDD 250 GB - SATA 3Gb/s - 7200 rpm
Optical Storage
DVD
Graphics Controller
Matrox G200
GigE
17.5 cm x 47.3 cm x 36.7 cm
12.2 kg
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
Regional Warranty Exceptions
Brazil - 3 years (1 year on-site)
Server
Recommended Use
Small business, corporate business
Product Form Factor
Micro tower - 4U
Server Scalability
1-way
Internal Bays Qty
4
Front Accessible Bays Qty
2
Processor / Chipset
CPU
Intel Pentium G840
Clock Speed
2.8 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
2 GB / 16 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 2 GB
Hard Drive
HDD
1 x 250 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Storage Controller Name
Smart Array B110i
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD-ROM DVD - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Integrated
Interface (Bus) Type
PCI Express 2.0 x1
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
2 x HP NC112i
Remote Management Protocol
IPMI 2.0
Wake on LAN (WoL), ACPI support, PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 801.1p
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5" LFF
Slots
2 (total) / 2 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height (x1 mode) , 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 240-pin
1 x display / video , 1 x serial , 8 x USB (4 front, 4 rear) , 2 x LAN (Gigabit Ethernet)
System password, power-on password
FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438, ACPI 3.0b
Power supply
Power Provided
350 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
Regional Exceptions
17.5 cm
47.3 cm
36.7 cm
12.2 kg
10 °C
35 °C
10 - 90% (non-condensing)
Resources
The following resources are available for the HP ProLiant ML110 G7 2 GB RAM 2.8 GHz
