HP ProLiant ML10 Intel Pentium G2130 2GB (1x2GB)
Quicklinx: 9NTJWS00 Mfr#: 730651-421
  • Pentium
  • Red Hat Enterprise Linux
Are you looking for a standalone server for your small business? The HP ProLiant ML10 Server is a single-socket 4U tower server, delivering excellent value in a large form factor that small businesses require to run a small network environment. It provides entry-level businesses with an affordable server that can be used as a standalone tower configuration. It is outstanding for businesses looking for improved performance, number of available slots, and flexible storage options while staying within a tight budget.
  • Low Acquisition Cost for the Budget Conscious
    The HP ProLiant ML10 Server is ideal for the budget-conscious business looking for just right performance and features.It has the right server technology to be cost effective for small businesses, or as a first server.HP iLO 3 remote management allows network administrators to easily check and update servers remotely, eliminating offsite travel expenses.
  • Right Balance of Expandability and Efficiency
    A true server at a desktop price, the HP ProLiant ML10 Server delivers many years of expandability and operational efficiency for businesses.The large server chassis size reduces component failure greatly, while allowing for maximum air flow.The design allows for easy installation and convenient expansion to meet business needs, with support for up to four (4) large form factor (LFF) hard disk drives, seven (7) USB ports, and four (4) I/O slots.
  • Optimal Computing with Built-in Reliability
    The HP ProLiant ML10 Server comes standard with Error Correcting Code (ECC) memory that protects businesses data from data loss and unplanned system downtime.Smart Array controller options provide businesses with RAID mirroring and striping capabilities to protect critical storage data.Server class technology allows for 24x7 business operation, offering higher reliability and longer lifecycle.The global network of HP channel partners provides expertise and guidance.
HPE ProLiant ML10 Entry - micro tower - Pentium G2130 3.2 GHz - 2 GB - no HDD
Server - micro tower - system password, power-on password
Height (Rack Units)
4U
Region: Europe
Server Scalability
1-way
1 x Intel Pentium G2130 / 3.2 GHz (Dual-Core)
Processor Main Features
Hyper-Threading Technology
Cache Memory
3 MB L3 Cache
Cache Per Processor
3 MB
RAM
2 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 3Gb/s) (Smart Array B110i)
Hard Drive
No HDD
Optical Storage
No optical drive
GigE
16.5 cm x 38.1 cm x 36.39 cm
5.94 kg
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Micro tower - 4U
Server Scalability
1-way
Internal Bays Qty
2
Front Accessible Bays Qty
1
Region: Europe
Processor / Chipset
CPU
Intel Pentium G2130
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel C204
Cache Memory
Installed Size
L3 Cache - 3 MB
Cache Per Processor
3 MB
RAM
Installed Size
2 GB / 32 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 2 GB
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Storage Controller Name
Smart Array B110i
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Integrated
Ethernet Controller
HP NC112i
Remote Management Protocol
IPMI 2.0
Wake on LAN (WoL), ACPI support, PXE support
Bays
1 (total) / 1 (free) x external 5.25" x 1/2H , 2 (total) / 2 (free) x internal 3.5" LFF
Slots
1 (total) / 1 (free) x PCIe 2.0 x16 - full-length, full-height , 2 (total) / 2 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x4 - full-length, full-height (x1 mode) , 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 240-pin
6 x USB 2.0 (2 front, 4 rear) , 1 x LAN (Gigabit Ethernet) , 1 x HPE iLO
System password, power-on password
FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438, ACPI 3.0b
Power supply
Power Provided
300 Watt
80 PLUS Certification
80 PLUS Bronze
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
16.5 cm
38.1 cm
36.39 cm
5.94 kg
10 °C
35 °C
10 - 90% (non-condensing)
