HP ProLiant DL160 G6 Quad Core Xeon E5504 4GB 160GB
Quicklinx: 62M8WS00 Mfr#: 490427-421
  • Xeon
  • Red Hat Enterprise Linux
The HP ProLiant DL160 G6 is a high performance, low cost, ultra-dense rack server designed for memory intensive High Performance Computing (HPC) environments, web serving and memory intensive applications.
  • Easy to Own
    Affordable pricing for a well-featured dual processor system.Rack-optimized, 1U form-factor for fast deployment and efficient maintenance of large-scale cluster and grid solutions.Easy-access chassis and internal component labels make maintenance and expansion fast and simple.Addition of the Easy Setup CD for rapid deployments.Addition of SNMP agents for more comprehensive management.
  • Right-Sized Solution
    Choice of the latest 4 and 6 core Intel Xeon Processors.Performance for 32-bit and 64-bit application solutions.Offers standard industry leading DDR3 Registered and Unbuffered DIMMs with expansion to 192 GB to provide increased bandwidth for high uptime and memory intensive performance.Integrated HPE NC362i dual-port 1Gb NIC that features load-balancing, failover, and sideband support.Now even more scalable internal bays to meet your storage needs with up to four Large Form Factor 3.5 inch non-hot plug SATA or hot plug SATA/SAS or support of up to eight 2.5 inch Small Form Factor hot plug SATA/SAS hard drive bays.
  • Support
    Global server support network to assist you with setup, installation and to provide reliable after sales support when you need it from a single point of contact.HPE provides a broad choice of pre-configured, factory-integrated and tested cluster packages ideal for midrange technical computing.
  • Energy Efficiency Leadership
    Introducing up to 94% efficiency power supply. Delivering the highest efficiency in the industry, as seen by meeting Climate Savers Computing Gold, 80PLUS Gold and setting the standards for Energy Star for Servers compliance.Right-sized ProLiant power supplies meet the exact needs, reclaiming lost data center power. Less oversubscription means more capacity opportunity. Be sure to use the HPE Power Calculator for selecting the right size power supply.ProLiant G6 systems can tell when power is being wasted and compensate for it. Smart Sensors throughout the server allow intelligent actions to preserve, protect and enhance performance and power savings.
HPE ProLiant DL160 G6 - rack-mountable - Xeon E5504 2 GHz - 4 GB - HDD 160 GB
Server - rack-mountable - administrator password, power-on password, keyboard password
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon E5504 / 2 GHz (Quad-Core)
Processor Socket
LGA1366 Socket
Cache Memory
4 MB L3 Cache
Cache Per Processor
4 MB
RAM
4 GB (installed) / 48 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-10600
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
HDD 160 GB - SATA 3Gb/s - 7200 rpm
Optical Storage
No optical drive
GigE
Software Included
Drivers & Utilities
Windows Server Certified
This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
44.8 cm x 68.2 cm x 4.3 cm
16.8 kg
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Internal Bays Qty
4
Front Accessible Bays Qty
1
Processor / Chipset
CPU
Intel Xeon E5504
Clock Speed
2 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA1366 Socket
Chipset Type
Intel 5520
Cache Memory
Installed Size
L3 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB / 48 GB (max)
Effective Memory Speed
800 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
18 (Total) / 16 (empty)
Unbuffered
Configuration Features
2 x 2 GB
RAM Supported
PC3-10600 - 288 GB registered - ECC , PC3-10600 - 48 GB unbuffered - ECC
Hard Drive
HDD
1 x 160 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
SATA
Controller Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Max Allocated RAM Size
32 MB
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC362i
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 4 (total) / 3 (free) x internal 3.5" x 1/3H
Slots
1 (total) / 1 (free) x PCIe x4 - low-profile , 1 (total) / 1 (free) x PCIe x16 , 18 (total) / 16 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU
1 x serial , 1 x VGA , 4 x USB , 2 x LAN (Gigabit Ethernet)
Administrator password, power-on password, keyboard password
ACPI 2.0
Power supply
Power Provided
500 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, SunSoft Solaris x86 10, SunSoft Solaris x64 10
Software
Drivers & Utilities
44.8 cm
68.2 cm
4.3 cm
16.8 kg
10 °C
35 °C
10 - 85%
