HP ProDisplay P223A LED Monitor 21.5" 1920 x 1080 Full HD
Quicklinx: CTCVWS00 Mfr#: X7R62AA#ABU
Put your HP Pro PC content front and center on an ample 21.5-inch diagonal FHD screen with the HP ProDisplay P223a 21.5-inch Monitor. The sleek, highly affordable design delivers essential presentation features, integrated speakers, and advanced connectivity for your everyday business productivity.
Now hear this
Enjoy stereo audio at the display—no external speakers required! With an audio signal streamed over the DisplayPort™ connection or the traditional audio jack, you get a complete media experience without the extra clutter.
Fabulous front-of-screen
Get crisp image clarity for all your content on the 54.6 cm (21.5") diagonal screen with 1920 x 1080 resolution, and 3000:1 contrast ratio. 178-degree viewing angles mean everybody has a great view.
High-speed connectivity and FHD imagery
Experience stunning FHD picture quality, ultra-fast graphics refresh, and vivid colors from the DisplayPort™ connection, which also supports multiple display connections from a single PC. Get legacy device compatibility from the VGA connector.
Create an efficient, easy-to-use workspace
Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
  • Be energy smart
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient, low halogen design that is ENERGY STAR and TCO certified and EPEAT Gold registered.
  • Plan ahead
    Deploy this Global Series display across your business. It has a stable product lifecycle, minimum one-year lifespan, and is available around the world.
  • Place it where you need it
    Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern, including the HP Adjustable Dual Display Stand, which holds two displays in a single-stand footprint.
  • Complete the picture
    Customize a total solution with options designed for your display.
  • Divide and conquer
    Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by deactivating a display that's disconnected without approval.
  • Global reassurance
    Rest assured that your IT investment is supported by a three-year standard limited warranty. Add HP Care services to extend your protection beyond the standard limited warranties.
HP ProDisplay P223A - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
51.5 cm x 19.12 cm x 38.9 cm
3.5 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, KCC, KC, CECP, EPA, ISC, CEL Grade 2, SEPA, ICE
3-year warranty
Display Type
Diagonal Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102.4
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Mercury free, arsenic free
51.5 cm x 19.12 cm x 38.9 cm - with stand
3.5 kg
Audio
Speakers - stereo
Output Power / Channel
1 watt
DisplayPort (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Input Voltage
Power Consumption (Typical)
20 watt
Power Consumption Sleep
0.5 watt
Included Software
Display drivers, HP Display Assistant
Dimensions & Weight Details
With stand - width: 51.5 cm - depth: 19.12 cm - height: 38.9 cm - weight: 3.5 kg , Without stand - width: 51.5 cm - depth: 5.49 cm - height: 32.7 cm - weight: 2.9 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
CTCV HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £6.04
