HP ProDisplay P223 1920x1080 Full HD 21.5" LED Monitor
Quicklinx: DC5VWS00 Mfr#: X7R61AA#ABU
Put your HP Pro PC content front and center on an ample 21.5-inch diagonal FHD screen with the HP ProDisplay P223 21.5-inch monitor.
  • Be energy smart
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient, low halogen design that is ENERGY STAR and TCO certified and EPEAT 2019 registered.
  • Plan ahead
    Deploy this Global Series display across your business. It has a stable product lifecycle, minimum one-year lifespan, and is available around the world.
  • Place it where you need it
    Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern, including the HP Adjustable Dual Display Stand, which holds two displays in a single-stand footprint.
  • Complete the picture
    Customize a total solution with options designed for your display.
  • Divide and conquer
    Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by deactivating a display that's disconnected without approval.
  • Global reassurance
    Rest assured that your IT investment is supported by a three-year standard limited warranty. Add HP Care services to extend your protection beyond the standard limited warranties.
HP ProDisplay P223 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
51.5 cm x 19.12 cm x 38.9 cm
3.5 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, EPA, Directive 2002/95/EC, ISC, CEL Grade 2, WEEE 2002/96/EC, SEPA, low halogen, ICE
Display Type
Diagonal Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102.4
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Frame Rate Control (FRC), Mercury free, arsenic free
51.5 cm x 19.12 cm x 38.9 cm - with stand
3.5 kg
DisplayPort (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m
Backlight Life
30,000 hours
Input Voltage
Power Consumption (Typical)
20 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Display drivers, HP Display Assistant
Dimensions & Weight Details
With stand - width: 51.5 cm - depth: 19.12 cm - height: 38.9 cm - weight: 3.5 kg , Without stand - width: 51.5 cm - depth: 5.49 cm - height: 32.7 cm - weight: 2.9 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
