HP ProDisplay P203 1660x900 20" LED Monitor
Quicklinx: DC5TWS00 Mfr#: X7R53AA#ABU
Get essential presentation features and advanced connectivity for your PC or notebook with the HP ProDisplay P203 monitor.
  • Fabulous front-of-screen
    Enjoy crisp, clear HD color for all of your content on the 50.8 cm (20") diagonal screen with 1600 x900 resolution, 5 ms response time, and 1000:1 contrast ratio.
  • High-speed connectivity and HD imagery
    Experience stunning HD picture quality, ultra-fast graphics refresh, and vivid colors from the DisplayPort connection, which also supports multiple display connections from a single PC. Get legacy device compatibility from the VGA connector.
  • Create an efficient, easy-to-use workspace
    Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
  • Be energy smart
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient, low halogen design that is ENERGY STAR and TCO certified and EPEAT 2019 registered.
HP ProDisplay P203 - LED monitor - 20"
LED-backlit LCD monitor - 20"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
48.2 cm x 19.1 cm x 37.1 cm
3.3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, ICE
3-year warranty
Display Type
Diagonal Size
20"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.276 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 70 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Mercury free, arsenic free
48.2 cm x 19.1 cm x 37.1 cm - with stand
3.3 kg
DisplayPort (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
Backlight Life
30,000 hours
Input Voltage
Power Consumption (Typical)
17.8 Watt
Power Consumption Sleep
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 48.2 cm - depth: 19.1 cm - height: 37.1 cm - weight: 3.3 kg , Without stand - width: 48.2 cm - depth: 5.5 cm - height: 30.8 cm - weight: 2.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
