HP ProDisplay P201 20-In LED Monitor - VGA - 1600x1900
Quicklinx: 8NMJWS00 Mfr#: C9F26AT#ABU
Keep up the good work with solid performance, a stylish design, and environmental features all at an attractive price point with the HP ProDisplay P201 50,8 cm (20') LED Backlit Monitor. Efficiently grow and maintain your business with proven HP quality and reliability, stable lifecycles, HP accessory compatibility, and energy savings. Do more throughout the day and help save more throughout the quarter with a monitor that goes the distance.
  • Essential business features
    Support your business needs wherever you need a solid performing monitor at a competitive price with a 50,8 cm (20') diagonal LED business display.See the difference with an LED display for vibrant text and graphics presentation. LED technology also makes your display thin, light, and easy to position on the desk.Deliver clear views for single and multiple users with wide viewing angles. High contrast ratios and fast response times keep your content crisp and readable throughout the day.Work comfortably with up to 30 degrees of tilt on the adjustable design, and easily connect to devices with convenient VGA and DVI inputs. The internal power supply minimizes clutter on the desktop and simplifies setup and deployment.
  • Compatibility with HP accessories
    Customize your work space with options like the HP Quick Release, HP Speaker Bar and HP USB Graphics Adapter (options sold separately).Free up valuable space and lift the monitor completely off the desk. The 100-mm standard VESA pattern allows mounting on a HP Monitor Arm, HP Stand, the HP Quick Release and other VESA-compatible accessories (options sold separately).
  • Stability now, and peace of mind for the future
    Maintain product consistency across staggered deployments, ease transitions and help reduce support costs with a minimum one-year lifecycle stability commitment from HP.Support identical installations and unify your operations worldwide with globally consistent products in over 145 countries.Get improved reliability and peace of mind from HP quality standard testing that puts our monitors through their paces before you do.Rest assured that your IT investment is supported by a standard, three-year limited warranty. Select HP Care Pack Services to extend service contracts beyond the standard warranties.
  • Smart software for the multi-tasker
    HP Display Assistant consolidates monitor setting controls into one easy-to-use, centralized interface.Customize your workspace with resizable screen partitions that let you work on a document in one partition, refer to a spreadsheet in another, and check e-mails in another-at the same time.Use the new expanded toolbar to view the applications you're using across all of your connected displays.
  • Energy efficient, environmentally aware
    Mercury-Free LED backlighting, a BFR/PVC-free design, and arsenic-free display glass are just a few of the environmental features built into this display.Help lower your overall bottom line with award-winning eco-certifications, including ENERGY STAR , EPEAT Gold and TCO.
HP ProDisplay P201 - LED monitor - 20" - Smart Buy
LED-backlit LCD monitor - 20"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.2768 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
48.2 cm x 15.11 cm x 35.92 cm
3.5 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV, VCCI, BSMI CNS 13438 Class B, CCIB, cUL, GS, EN55022 Class B, FCC Part 15 B, CCEE, EN55024 Class B, UL 60950-1, IEC 60950-1, EN 60950-1, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, CISPR, GEEA, AS/NZS 3548 Class B, MEPS, CSA C22.2 No. 60950-1, KC, CEL
3-year warranty
Display Type
Diagonal Size
20"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.2768 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Video Bandwidth
140 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
9300K, 6500K
Controls & Adjustments
Brightness, contrast, colour temperature, clock
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP
48.2 cm x 15.11 cm x 35.92 cm - with stand
3.5 kg
DVI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m
Backlight Life
30,000 hours
HP Smart Buy
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
20 Watt
Included Software
Dimensions & Weight Details
With stand - width: 48.2 cm - depth: 15.11 cm - height: 35.92 cm - weight: 3.5 kg , Without stand - width: 48.2 cm - depth: 4.75 cm - height: 29.41 cm - weight: 2.9 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years - on-site
5 °C
35 °C
20 - 80% (non-condensing)
