Get productive with an essential business monitor featuring solid performance, a 5:4 aspect ratio for business-specific applications, and energy savings–all at an attractive price point. Grow with a stylish monitor backed by HP reliability, a stable lifecycle, and HP accessory compatibility.
Get comfortable
Customize your display's position with adjustable tilt settings and 170-degree horizontal and 160-degree vertical viewing angles. -
Mount on a wall with the HP Quick Release and standard 100-mm VESA pattern. Keep it compact with the HP Integrated Work Center Stand and a PC or thin client. Boost audio with the HP Speaker Bar. -
Your monitor's new best friend
Personalize your workspace with HP Display Assistant software and view open applications on all of your connected displays. -
Global reassurance
Rest assured that your IT investment is supported by a three-year standard limited warranty. To extend your protection beyond the standard warranties, select optional HP Care Pack Services.
- HP ProDisplay P17A - LED monitor - 17"
- LED-backlit LCD monitor - 17"
- Panel Type
- TN
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 37.72 cm x 20.63 cm x 38.72 cm
- 3.72 kg
- Localisation
- English / United States
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV, VCCI, BSMI CNS 13438 Class B, CCIB, cUL, GS, EN55022 Class B, CCEE, FCC Part 15, EN55024 Class B, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, WEEE, CISPR, GEEA, CSA C22.2 No. 60950-1, KC, CEL
- Display Type
- Diagonal Size
- 17"
- Panel Type
- TN
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 24 - 83 kHz
- Video Bandwidth
- 140 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- Controls & Adjustments
- Brightness, contrast, colour temperature
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Black
- 37.72 cm x 20.63 cm x 38.72 cm - with stand
- 3.72 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- Cables Included
- 1 x VGA cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 37.72 cm - depth: 20.63 cm - height: 38.72 cm - weight: 3.72 kg , Without stand - width: 37.72 cm - depth: 5.7 cm - height: 31.66 cm - weight: 3.23 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
