HP ProDisplay P17A - LED monitor - 17" - 1280 x 1024
Quicklinx: C9VZWS00 Mfr#: F4M97AA#ABU
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
34 in stock
£83.00 ex VAT
£99.60 inc VAT
Get productive with an essential business monitor featuring solid performance, a 5:4 aspect ratio for business-specific applications, and energy savings–all at an attractive price point. Grow with a stylish monitor backed by HP reliability, a stable lifecycle, and HP accessory compatibility.
  • Business-class presentation features
    Get crisp, clear views of your documents and e-mail with 1280 x 1024 resolution and 5 ms response time on a 43,18 cm (17') diagonal screen. Quickly connect to your devices with a VGA input. Keep your work space tidy with the internal power supply.
  • Stay the course
    Keep the 5:4 aspect ratio that your business-specific enterprise and public sector applications are designed to work with.
  • Budget-friendly product stability
    Get a stable product lifecycle and minimum one-year lifespan at a price point that's easy on your wallet. Be confident in the improved reliability of a monitor that has been through its paces with HP quality standard testing.
  • Designed with the environment in mind
    Reduce power consumption and lower costs with an energy efficient design that is ENERGY STAR and TCO qualified and EPEAT 2019 registered. Includes mercury-free display backlights, low halogen design, and arsenic-free display glass.
Display Type
Diagonal Size
17"
Viewable Size
17"
Panel Type
TN
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Video Bandwidth
140 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
Controls & Adjustments
Brightness, contrast, colour temperature
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
72% colour gamut
37.72 cm x 20.63 cm x 38.72 cm - with stand
3.72 kg
VGA
Mechanical
Display Position Adjustments
Tilt
Tilt Angle
-5/+25
1 x VGA cable - 1.8 m
Backlight Life
30,000 hours
Plug and Play, FCC Class B certified, TUV, VCCI, BSMI CNS 13438 Class B, CCIB, cUL, GS, EN55022 Class B, CCEE, FCC Part 15, EN55024 Class B, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, WEEE, CISPR, GEEA, CSA C22.2 No. 60950-1, KC, CEL
English / United Kingdom
Power Supply
Internal
20 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 37.72 cm - depth: 20.63 cm - height: 38.72 cm - weight: 3.72 kg , Without stand - width: 37.72 cm - depth: 5.7 cm - height: 31.66 cm - weight: 3.23 kg
Environmental Standards
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
HP ProDisplay P17A - LED monitor - 17 Bundle deal on HP ProDisplay P17A - LED monitor - 17" - 1280 x 1024
£182.17
Diagonal Size: 17in
Response Time: 5ms
Speakers: None
Brand: HP
Price Range Ex VAT: 50 - 100
