Maximize small work spaces with an affordable HP ProDisplay Companion Stand, which enables you to create a compact desktop solution by combining an HP ProDisplay Monitor with your choice of platform.
Easy assembly
Simply attach your HP ProDisplay head to the front of the stand and attach your HP Desktop Mini, Chromebox, Thin Client or USDT to the back of the monitor using the integrated HP Quick Release mounting plate. -
Keep it clean and secure
Store your PC power brick out of the way on the built-in tray. Use the optional HP Security Lock to help deter theft or tampering of the PC or display. -
Work comfortably
Find your best viewing position with adjustable tilt settings. -
Rest easy
Get the reassurance of a one-year parts replacement limited warranty.
- HP Companion Stand - monitor stand
- Product Type
- Monitor stand
- 23.6 cm x 19.2 cm x 11.9 cm
- 850 g
- Designed For
- HP 260 G2; ProDisplay P191, P221
- Product Type
- Monitor stand
- VESA Mounting Interface
- 100 x 100 mm
- 23.6 cm - 19.2 cm - 11.9 cm
- 850 g
- HP Quick Release
- Designed For
- HP 260 G2 , HP ProDisplay P191, P221
