Deploy the stylish, compact, reliable HP ProDesk 600 Desktop Mini from the open office to the back office in your modern workspace with its powerful performance and built-in security in a highly adaptable form factor.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP. -
Fast performance, connectivity, and responsiveness
Get the exceptional combination of responsive performance, connectivity and speed with a 10th Gen Intel Core processor that lets you launch, create, and connect fast and reliably. -
Browse confidently
Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click. -
HP Sure Sense
Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
- HP ProDesk 600 G6 - mini desktop - Core i5 10500T 2.3 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - mini desktop
- Localisation
- Processor
- Intel Core i5 (10th Gen) 10500T / 2.3 GHz (, up to 3.8 GHz, (6-core)
- Processor Socket
- FCLGA1200 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 12 MB L3 Cache
- Cache Per Processor
- 12 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express 3.0 - M.2 2280 - NVM Express (NVMe), triple-level cell (TLC)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 630 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.1, Wi-Fi 6
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- HP Support Assistant, HP Secure Erase, HP JumpStart, HP Noise Cancellation, HP Sure Click, HP Sure Sense, HP Sure Recover Gen3, HP Client Security Manager Gen6, HP SureStart Gen6, HP Sure Run Gen3, HP BIOSphere Gen6, HP DriveLock, HP Desktop Support Utility
- 17.7 cm x 17.5 cm x 3.42 cm
- 1.25 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini desktop
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA1200 Socket
- Chipset Type
- Intel Q470
Cache Memory
- Installed Size
- L3 Cache - 12 MB
- 12 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express 3.0
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP 320K
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wi-Fi 6 AX 201
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.1, IEEE 802.11ax (Wi-Fi 6)
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support, dual stream (2x2)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax
- Bays
- 1 (total) / 1 (free) x internal 2.5" x 1/8H
- Slots
- 1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 2 (total) / 1 (free) x M.2 Card - 2280 (x4 mode)
- 3 x USB 3.2 Gen 1 (1 front, 2 rear) , 3 x USB 3.2 Gen 2 (1 front, 2 rear) , 1 x USB-C 3.2 Gen 2 (1 in front) , 2 x DisplayPort , 1 x headphones/microphone (1 in front) (CTIA and OMTP headset support) , 1 x LAN (Gigabit Ethernet) , 1 x VGA
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- ACPI, FCC Class B certified, ICES-003, CCC, UL 60950-1, KCC Class B, Common Criteria EAL4+, CAN/CSA C22.2 No. 60950-1-07, VCCI Class B, WEEE 2002/96/EC, low halogen, UL 62368-1, RoHS 2011/65/EC, CAN/CSA-C22.2 No. 62368-1-14
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 89% (230VAC), 88% (115VAC)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- 17.7 cm
- 17.5 cm
- 3.42 cm
- 1.25 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 22.3 cm
- Shipping Weight
- 2.97 kg
- 5 °C
- 35 °C
- 5 - 90% (non-condensing)
Warranties (6)
HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service | In Stock | £31.67 |
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £16.84 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £49.10 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £33.69 |
HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site | In Stock | £41.17 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site | In Stock | £70.47 |
Monitors (2)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £150.00 |
Other bundles (4)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE DisplayPort DVI-D Adapter | In Stock | £13.23 |
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
