Future-ready reliability and performance
Designed to fit the modern workspace, the stylish and ultra-small HP ProDesk 600 Desktop Mini is a powerful and reliable PC with performance, security, and manageability features for your business.
Business-ready performance, nicely packaged
Power through your day with a solution you can flexibly configure with an 8th Gen Intel® Core™ processor and options that include Intel® Optane™ memory, SSD storage, and up to 32 GB of DDR4 memory.
Expansion that extends your investment
Maximize the life of your PC with options4 that let you expand on your own schedule, including dual M.2 slots which allow for SSD RAID, traditional SATA drives, and a configurable I/O port.
Place it where you need it
Take your footprint down to near zero with a PC that attaches behind an HP EliteDisplay, or mount and secure it almost anywhere with HP accessories.4 Declutter with USB-C™, short cables, and rear I/O ports that connect to a range of displays.
HP exclusive security and manageability
Protect against BIOS attacks with HP Sure Start Gen4. Help prevent data breaches and downtime with HP BIOSphere Gen48 and easily manage devices through Microsoft System Centre Configuration Manager with HP Manageability Integration Kit
The full value of your investment comes with expansion that extends the life of your PC. The HP ProDesk 600 SFF has two bays, two slots, and two M.2 connectors. -
Built on a secure foundation
Protect your PC against the evolving malware threats of the future, with HP's self-healing, hardware-enforced, and manageable security solutions. From the BIOS to the browser HP Sure Start Gen4 and HP Sure Click help secure your PC. -
Connection hub
With 11 total USB ports including one USB Type-C, the HP ProDesk 600 SFF becomes a hub for all your devices in the office.
- HP ProDesk 600 G4 - mini desktop - Core i5 8500T 2.1 GHz - 8 GB - HDD 1 TB - UK
- Personal computer - mini desktop
- Localisation
- Processor
- Intel Core i5 (8th Gen) 8500T / 2.1 GHz (, up to 3.5 GHz, (6-core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 630 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- HP Recovery Manager, HP Support Assistant, HP Hotkey Support, HP Spare Key, Password Manager, Windows Defender, HP Secure Erase, HP Manageability, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Credential Manager, HP Client Catalogue (free download), HP Driver Packs, HP Device Access Manager, HP JumpStart, HP Noise Cancellation, HP System Software Manager (free download), HP PhoneWise, HP Sure Click, HP BIOSphere Gen4, HP Client Security Suite Gen4, Power On Authentication, HP SureStart Gen4, Ivanti Management Suite, HP Management Integration Kit for Microsoft System Center Configuration Manager Gen 2
- 17.7 cm x 17.5 cm x 3.4 cm
- 1.25 kg
- Personal computer
- Product Form Factor
- Mini desktop
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q370
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Interface (Bus) Type
- M.2 Card
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 5.0
- Bays
- 1 (total) / 0 (free) x internal 2.5" x 1/8H
- Slots
- 1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2230/2280 (x4 mode)
- 3 x USB 3.1 Gen 1 (1 front, 2 rear) (two of them with wake functionality) , USB 3.1 Gen 2 (1 front, 2 rear) , 2 x DisplayPort , 1 x VGA , 1 x USB-C 3.1 Gen 2 (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x headphones/microphone (1 in front)
- Included Accessories
- HP Desktop Mini Vertical Chassis Stand
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, low halogen
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- 17.7 cm
- 17.5 cm
- 3.4 cm
- 1.25 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 22.3 cm
- Shipping Weight
- 2.97 kg
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
