HP ProDesk 600 G1 SFF Intel Pentium Dual Core 3250 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BC3TWS00 Mfr#: J7C48EA#ABU
  • Pentium
  • Red Hat Enterprise Linux
  • Microsoft Windows 7 Professional 64-bit Edition
Productivity and manageability in one. Give busy workers the edge they need to stay ahead. This PC's solid-state hybrid drive responds to the speed of work and opens applications right away. Powerful security and business-class management software frees up IT staff time.
  • Less waiting around
    Speedy and responsive to keep pace with your multitasking. Quickly open new files and switch applications with less wait time, thanks to an optional solid-state hybrid drive.Power through your day with greater speed and performance. Get the latest in processing technology with your choice of 4th generation Intel Core processors.Easily share your internet connection with your devices and help colleagues get online fast with HP Wireless Hotspot.
  • Keep everything in sight
    Watch your inbox while working on other tasks. There's plenty of screen room for all of your work with support for multiple displays.Make the most of virtual conferencing. Bring work to life through rich sound and video with DTS Sound+ and an HD webcam.Keep your most important devices easily connected. Access and transfer data fast with two front USB 3.0 ports.Share presentations, videos, and other content-no cables needed. WiDi Intel Wireless Display lets you connect your ProDesk to projectors and other WiDi-ready devices.Put in more face time. You're ready for web chats and conferences with Skype pre-configured on your HP ProDesk 600 G1. It's almost as good as being there.
  • Hassle-free security and management
    HP Client Security software suit helps you quickly and easily encrypt your hard drive, permanently delete unwanted or discarded data, restrict unauthorized access, and more.Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks and other security threats, and is designed to help prevent data loss and reduce downtime.You can help safeguard your data with easy backup and recovery, using HP Recovery Manager.Securely store all of your passwords and speed up access to your favorite password protected applications with HP Password Manager.Get right to the updates you need and spend less time managing updates with HP Support Assistant.
  • Plan with confidence
    Get more out of your investment. The HP ProDesk 600 G1 is designed for a long lifecycle, with platform stability up to 30 months.HP ProDesk PCs are rigorously tested to help ensure reliability. During the HP Total Test Process, our PCs experience 115,000 hours of performance trials to help get you through your business day.Add a little style to the workplace. HP business PCs feature a new industrial design with rounded edges and other features to help the system look newer for longer.
HP ProDesk 600 G1 - SFF - Pentium G3250 3.2 GHz - 4 GB - HDD 500 GB - TAA Compliant
Personal computer - small form factor - administrator password, power-on password, serial port I/O control, USB port control, DriveLock, Intel Standard Manageability, Setup Password
Intel Pentium G3250 / 3.2 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics Dynamic Video Memory Technology
Audio Output
Stereo - integrated
1GbE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Support Assistant, Bing Toolbar, HP ePrint, Foxit PhantomPDF Express, Microsoft Internet Explorer 10, Device Access Manager, HP Client Security, HP PageLift, HP File Sanitizer, Box, Drive Encryption, HP Disk Sanitizer External Edition (free download)
33.8 cm x 37.9 cm x 10 cm
7.6 kg
TAA Compliant
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Intel Pentium G3250
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q85
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
1333 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Integrated
Ethernet Controller
Intel I217-LM
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 3.5" , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x PCIe x16 , 3 (total) / 3 (free) x PCIe x1 , 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 240-pin
6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Administrator password, power-on password, serial port I/O control, USB port control, DriveLock, Intel Standard Manageability, Setup Password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
TAA Compliant
Power supply
Power Provided
240 Watt
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
OS Certified
Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
Software
33.8 cm
37.9 cm
10 cm
7.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
