Productivity and manageability in one. Give busy workers the edge they need to stay ahead. Powerful security and business-class management software frees up IT staff time.
Big power
Smaller than some desk phones, this Desktop Mini can fit almost anywhere vertically or horizontally. The clean, easily serviceable design with integrated wireless antenna allows flexible deployment options to help optimize the workspace.Be up to 35% more productive by adding up to three independent displays using the integrated DisplayPort with Multi-Stream video outputs.Set up the HP ProDesk 600 G1 Desktop Mini in almost any spot or easily attach to several optional peripheral devices using the integrated VESA mount.The HP ProDesk 600 Desktop Mini G1 withstands 115,000 hours of the HP Total Test Process so you get confidence built right in.Easily service the HP ProDesk 600 G1 Desktop Mini. A single thumb screw provides fast access to clearly identifiable and serviceable components. -
Full ProDesk functionality
Keep productivity high and downtime low with HP BIOSphere firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.Power through your day with speed and performance. Get the latest in processing technology with your choice of 4th generation Intel Core processors.Take advantage of new drive technology with an optional M.2 PCIe solid state hard drive module, the internal 2.5" SSD, or dual drive configurations for more local storage.Make the most of virtual conferencing. Bring work to life through rich sound and video using DTS Studio Sound Audio software.Put in more face time. You're ready for web chats and conferences with Skype pre-configured on your HP ProDesk 600. It's almost as good as being there. -
Solid security
HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.HP Secure Erase removes the contents of a hard drive for repurposing or reassignment.Get extra protection with secured storage and ensured platform integrity thanks to the Trusted Platform Module security chip used by the BIOS and the Operating System.Keep sensitive information in safe hands. HP Trust Circles helps protect your data by ensuring that only assigned contacts can access critical files. -
Green with envy
The low energy consumption levels of this ENERGY STAR qualified and EPEAT Gold certified PC supports 24/7 operations. Consuming less than 8W of power at idle your Desktop Mini can be always on and always updated.
- HP ProDesk 600 G1 - mini desktop - Core i3 4360T 3.2 GHz - 4 GB - HDD 500 GB - UK - TAA Compliant
- Personal computer - mini desktop - administrator password, power-on password, USB port control, DriveLock, Intel Identity Protection Technology (Intel IPT), Setup Password
- Localisation
- Processor
- Intel Core i3 (4th Gen) 4360T / 3.2 GHz (Dual-Core)
- Cache Memory
- 4 MB
- Cache Per Processor
- 4 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 4600 Dynamic Video Memory Technology
- Audio Output
- Stereo - integrated
- Networking
- 1GbE, 802.11a, 802.11b/g/n
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Support Assistant, Bing Toolbar, HP ePrint, PDF Complete Corporate Edition, Microsoft Internet Explorer 10, Device Access Manager, HP Client Security, HP PageLift, HP File Sanitizer, Drive Encryption, Box.net, HP Disk Sanitizer External Edition (free download)
- 17.5 cm x 17.7 cm x 3.4 cm
- 1.3 kg
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Mini desktop
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q85
Cache Memory
- Installed Size
- 4 MB
- 4 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS SOUND+
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
- Ethernet Controller
- Intel I217-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-N 7260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin , 2 (total) / 1 (free) x M.2 Card , 1 (total) / 0 (free) x CPU
- 4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Administrator password, power-on password, USB port control, DriveLock, Intel Identity Protection Technology (Intel IPT), Setup Password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 87%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
- OS Certified
- Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
- Software
Sustainability Information
- ENERGY STAR Certified
- 17.5 cm
- 17.7 cm
- 3.4 cm
- 1.3 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
