HP ProDesk 405 G2 MT AMD A8-6410 4GB 500GB Windows 8.1 with Bing
Quicklinx: B2ZRWS00 Mfr#: L3E37ES#ABU
  • Windows 8.1 64-bit Edition
Meet the demands of everyday business with the AMD powered HP ProDesk 405 G2 with the performance and security tools you need to help grow your business.
Expandability options.
Don't limit your business. The HP ProDesk 405 G2 MT can be upgraded and expanded as your needs change.
Functional design.
The HP ProDesk 405 G2 MT provides easy access to components in the tool-less chassis and connections for support of up to three displays to support your business.
Pure value, pure performance.
Experience the difference of AMD APUs with stunning graphic and video capabilities along with powerful processing to enhance productivity.
Safeguard data and devices.
Help keep sensitive data secure with rock solid security features like HP Client Security and HP BIOS Protection,6 as well as the embedded TPM 1.2.
  • The AMD Radeon™ Dual Graphics option on the HP ProDesk 405 provides outstanding visual experiences on HP displays.
  • Guard your data, device and identity with HP Client Security.
  • HP BIOS Protection's automated recovery restores a copy of the BIOS from a partition on the hard drive if crisis strikes.
  • With TPM 1.2 your critical data has protection with hardware-based encryption keys.
  • Rest easy with a ProDesk that endures 115,000 hours of testing to help ensure reliability in the most demanding work environments.
  • See more of your work with support for up to three independent displays and optional DisplayPort with multi-stream.
  • Rest easy and work confidently with dependable support options including a parts/labor/on-site limited warranty and parts availability for up to 5 years.
  • Optional HP Care Pack with Accidental Damage Protection helps you avoid out-of-pocket repair or replacement costs and delivers service right to your door.
  • Relax. You're backed by expert support when you extend and expand beyond your standard limited warranty with optional HP Care Packs.
  • Easily share your internet connection with devices or colleagues to get productive fast.
AMD APU
Real-world workloads and applications demand a balance of compute and graphics capabilities. AMD's unique Accelerated Processing Unit (APU) combines multiple CPU and AMD Radeon™ GPU cores on one small, energy efficient chip.
Processor Spec
Processor - AMD A8-6410
Codename - Beema
Core Count - 4
Boost Speed - 2400 MHz
Cache Size - 2 MB
Wattage - 15 W
Graphics - Radeon™ R5 Graphics
Graphics Core Count - 2
Graphics Max Speed - 800 MHz
  • Easy expandability
    Don't limit your business. The HP ProDesk 405 G2 can be upgraded and expanded as your needs change.
  • Functional design
    The HP ProDesk 405 G2 provides easy access to components in the toolless chassis.
  • Pure value, pure performance
    Experience the difference in performance with stunning graphic and video capabilities along with powerful processing to enhance productivity.
HP ProDesk 405 G2 - micro tower A8 6410 2 GHz - 4 GB - HDD 500 GB - UK - TAA Compliant
Personal computer - micro tower - administrator password, power-on password, serial port I/O control, USB port control, HP BIOS Protection
AMD A8 6410 / 2 GHz (up to 2.4 GHz, (Quad-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
AMD Radeon R5
Audio Output
Stereo - integrated
1GbE
Keyboard
OS Provided
Software Included
CyberLink Power2Go, Skype, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP PageLift, Box.net, HP Disk Sanitizer External Edition (free download), HP Wireless Hotspot
18.288 cm x 40.2 cm x 35.7 cm
5.8 kg
TAA Compliant
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Micro tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD A8 6410
Clock Speed
2 GHz
Max Turbo Speed
2.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
Effective Memory Speed
1600 MHz
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon R5
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS SOUND+
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Value Keyboard
USB
Localization & Layout
Mouse
USB
Integrated
Ethernet Controller
Realtek RTL8151GH-CG
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 2 (total) / 1 (free) x internal 3.5"
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 3 (total) / 3 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 240-pin
4 x USB 2.0 , 2 x USB 3.0 (2 in front) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45
Administrator password, power-on password, serial port I/O control, USB port control, HP BIOS Protection
Theft/Intrusion Protection
ACPI, RoHS, WEEE
TAA Compliant
Power supply
Power Provided
180 Watt
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 8.1 64-bit Edition English
Software
18.288 cm
40.2 cm
35.7 cm
5.8 kg
10 °C
35 °C
10 - 90% (non-condensing)
