Designed to fit the modern workspace, the small and reliable HP ProDesk 400 small form factor is equipped with strong security features and performance that's scalable to grow with your business.
Powerful options
Power through your day with a high-performance Intel Core processor and options that include Intel Optane memory H10 and SSD storage. -
Expansion that extends your investment
The full value of your investment comes with expansion that extends the life of your PC. The HP ProDesk 400 SFF has two bays and two slots - including storage and WLAN M.2 slots, and configurable ports to fit your peripheral needs. -
Built in security
HP Sure Sense uses advanced protection backed with deep-learning AI to help defend against never before seen threats. An intrusion sensor along with an integrated accessory cable lock help secure your cabled mouse and keyboard from theft.
- HP ProDesk 400 G7 - SFF Core i5 10500 3.1 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - SFF
- Localisation
- Processor
- Intel Core i5 (10th Gen) 10500 / 3.1 GHz (up to 4.5 GHz, (6-core)
- Processor Socket
- FCLGA1200 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 12 MB L3 Cache
- Cache Per Processor
- 12 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA/NVMe (SATA 6Gb/s / PCIe 3.0 x4 (NVMe))
- Hard Drive
- SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - NVM Express (NVMe), triple-level cell (TLC)
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel UHD Graphics 630
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- Power
- (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition National Academic
- Software Included
- HP Support Assistant, Windows Defender, Microsoft 365 (Trial), HP Secure Erase, HP Setup Integrated OOBE, HP JumpStart, HP Sure Click, Power On Authentication, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense, HP Client Security Manager Gen6, HP BIOSphere Gen6, HP DriveLock, HP Image Assistant Gen5, HP Desktop Support Utility, HP Noise Cancellation Software, Xerox DocuShare (30 days trial), HP Smart Support
- 27 cm x 30.3 cm x 9.5 cm
- 3.9 kg
- Pricing Type
- HP k-12 education
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- SFF
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.1 GHz
- Max Turbo Speed
- 4.5 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA1200 Socket
- Chipset Type
- Intel Q470
Cache Memory
- Installed Size
- L3 Cache - 12 MB
- 12 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
Storage Controller
- 1 x SATA/NVMe
- Controller Interface Type
- SATA 6Gb/s / PCIe 3.0 x4 (NVMe)
- Channel Qty
- 3
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I210-T1
- Data Link Protocol
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), auto-uplink (auto MDI/MDI-X), PXE 2.1 support
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 2x2.5" / 1x3.5" shared
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x M.2 Card - 2230 (PCIe 3.0 x1 mode and Intel CNVi wireless module) , 1 (total) / 0 (free) x M.2 Card - 2280 (PCIe 3.0 x4 mode) , 1 (total) / 1 (free) x Flex I/O
- 2 x USB 3.2 Gen 2 (2 in front) , 4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality) , 1 x headphones/microphone (1 in front) (CTIA and OMTP headset support) , 1 x audio line-out , 1 x HDMI , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 3 x USB 3.2 Gen 1
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- FCC Class B certified, ICES-003, CCC, FIPS 140-2 Level 2, RoHS, UL 60950-1, CSA C22.2 No. 60950-1-07, WEEE, KCC Class B, Common Criteria EAL4+, VCCI Class B, CP65, low halogen, UL 62368-1, CAN/CSA-C22.2 No. 62368-1-14, IEEE 1680.1
- Pricing Type
- HP k-12 education
- Power supply
- Voltage Required
- AC 90-264 V (50/60 Hz)
- Power Provided
- 210 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 89%, 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition National Academic English
- Software
Sustainability Information
- ENERGY STAR Certified
- 27 cm
- 30.3 cm
- 9.5 cm
- 3.9 kg
- Shipping Width
- 39.4 cm
- Shipping Depth
- 20.5 cm
- Shipping Height
- 49.9 cm
- Shipping Weight
- 6.97 kg
- 5 °C
- 35 °C
- 5 - 90% (non-condensing)
HPE DisplayPort DVI-D Adapter | In Stock | £11.22 |
HP USB-C to USB 3.0 | In Stock | £20.55 |
