Give your business the strong foundation it needs for growth with the affordable and reliable HP ProDesk 400 SFF. Designed with essential security and manageability features, the HP ProDesk 400 helps keep your business growing.
New powerful processors
New 6th Gen Intel® Core™ processors bring powerful processing with Intel® HD 530 Graphics. Available DDR4 memory helps meet the demands of today’s businesses.
Security from the start
HP BIOSphere and HP Client Security boost security and keep critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
Tested to go the distance
HP ProDesks are rigorously tested to help ensure reliability. During the HP Total Test Process, PCs experience 120,000 hours of performance trials to help get you through your business day.
Make the smart investment
The HP ProDesk 400 SFF helps affordably build a solid IT infrastructure for your growing business and fits in smaller workspaces for easy deployment.
Let nothing stand in your way
Help protect from today's security threats and maximize management and productivity features for business with Windows 10 Pro. -
Simplify device management
Activate, configure, patch, and update your devices from a single console. -
Communication made easy
Make conferencing from your PC as simple as the touch of a button with the optional HP Conferencing keyboard. -
Connect to more capabilities
Multiple displays have shown to help increase productivity by 35% and the HP ProDesk 400 SFF allows you to connect two optional HP Pro Displays right out-of-the-box. -
Green with envy
Reduce energy consumption and costs with ENERGY STAR and EPEAT Gold certified configurations. -
Valuable support at your service
Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that's available 24x7, covering multiple brands, devices and operating systems.
- HP ProDesk 400 G3 - SFF - Core i7 6700 3.4 GHz - 4 GB - SSD 128 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i7 (6th Gen) 6700 / 3.4 GHz (, up to 4 GHz, (Quad-Core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 4 GB DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 128 GB - SATA 6Gb/s
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 530
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition, Intel Wireless Display, HP Client Security, HP Security Manager, Drive Encryption, HP BIOSphere, HP Client Security Manager
- 9.5 cm x 29.95 cm x 27 cm
- 4.43 kg
- Manufacturer Selling Program
- HP Smart Buy
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 4 GB
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 128 GB
- Interface Type
- SATA 6Gb/s
- 3D V-NAND Technology
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio, DTS SOUND+
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Interface (Bus) Type
- PCI Express 1.1 x1
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Data Link Protocol
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5" / 3.5" shared
- Slots
- 1 (total) / 1 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin
- 4 x USB 3.0 (2 front, 2 rear) , 4 x USB 2.0 , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, Common Criteria EAL4+
- HP Smart Buy
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
- Efficiency
- 85%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Software
- 9.5 cm
- 29.95 cm
- 27 cm
- 4.43 kg
Warranties (1)
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £16.46 |
Other bundles (2)
HPE DisplayPort DVI-D Adapter | In Stock | £11.22 |
HPE DisplayPort to VGA Adapter | In Stock | £12.98 |
