HP ProDesk 400 G3 MT Intel Core i5-6500 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BXB5WS00 Mfr#: P5K00ET#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
Give your business the strong foundation it needs for growth with the affordable and reliable HP ProDesk 400 MT. Designed with essential security and manageability features, the HP ProDesk 400 helps keep your business growing.
  • New powerful processors and memory
    New 6th Gen Intel Core processors bring powerful processing with Intel HD 530 Graphics. Available DDR4 memory helps meet the demands of today's businesses.
  • Security from the start
    HP BIOSphere and HP Client Security boost security and keep critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
  • Tested to go the distance
    HP ProDesks are rigorously tested to help ensure reliability. During the HP Total Test Process, PCs experience 120,000 hours of performance trials to help get you through your business day.
  • Make the smart investment
    The HP ProDesk 400 MT helps affordably build a solid IT infrastructure for your growing business with scalability in major components that allow you to configure the right PC for each user.
HP ProDesk 400 G3 - micro tower Core i5 6500 3.2 GHz - 4 GB - HDD 500 GB - UK - TAA Compliant
Personal computer - micro tower
Intel Core i5 (6th Gen) 6500 / 3.2 GHz (up to 3.6 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 530 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Software Included
CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, CyberLink PowerDVD BD Edition, Windows Defender, HP Systems Software Manager (free download), HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Client Security Manager, HP CIK for Microsoft SCCM (free download)
16.5 cm x 35.5 cm x 35.88 cm
7.05 kg
Manufacturer Selling Program
HP Smart Buy
TAA Compliant
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Micro tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS SOUND+
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Value Keyboard
USB
Localization & Layout
Mouse
USB
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Realtek RTL8111HSH-CG
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5" / 3.5" shared
Slots
3 (total) / 3 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin
4 x USB 3.0 (2 front, 2 rear) , 4 x USB 2.0 , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
ACPI
HP Smart Buy
TAA Compliant
Power supply
80 PLUS Certification
80 PLUS Bronze
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Software
16.5 cm
35.5 cm
35.88 cm
7.05 kg
10 °C
35 °C
10 - 90% (non-condensing)
