HP ProDesk 400 G2.5 SFF Intel Core i3-4170 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BL0QWS00 Mfr#: M3X16EA#ABU
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
The HP ProDesk 400 SFF with a 44% reduction in size from the previous generation, takes up much less space without sacrificing the computing power and security needed for business computing.
  • Windows 8.1
    Start up and switch applications with the quick and fluid Windows 8.1.
  • Super secure. Super protected
    HP Client Security suite helps you quickly and easily encrypt your hard drive, permanently delete unwanted or discarded data, restrict unauthorized access, and more.
  • Rapid recovery
    HP BIOS Protection's automated recovery restores a copy of the BIOS from a partition on the hard drive if crisis strikes.
  • Help secure critical data
    With TPM 1.2, your critical data has protection with hardware-based encryption keys.
  • Perform at the speed of work
    Enjoy the business ready performance of 4th generation Intel Core processors equipped with a powerful chipset, processor support, and robust memory.
  • Impressive graphics
    Immerse yourself in the rich graphic experience provided by Intel graphics on your HP ProDesk 400 SFF.
HP ProDesk 400 G2.5 - SFF Core i3 4170 3.7 GHz - 4 GB - HDD 500 GB - UK
Personal computer - SFF - administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control, DriveLock, HP BIOS Protection, Miracast, HP Drive Encryption, Master Record Security, Pre-boot Authentication
Intel Core i3 (4th Gen) 4170 / 3.7 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM - non-ECC - PC3L-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 4400
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, CyberLink YouCam BE, HP Systems Software Manager (free download), HP Secure Erase, Drive Encryption, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Client Security Manager, Absolute Persistence, HP CIK for Microsoft SCCM (free download), HP Driver Packs (free download)
27 cm x 31.785 cm x 9.5 cm
4.5 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
SFF
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.7 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel H81
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3L-12800
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Keyboard
Keyboard
Keyboard Name
HP Standard Value Keyboard
USB
Localization & Layout
Ethernet Controller
Realtek RTL8111HSH-CG
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5" / 3.5" shared , 1 (total) / 1 (free) x external
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 2.0 x1
2 x USB 3.0 (2 in front) , 6 x USB 2.0 , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , 1 x audio line-in , 1 x headphones (1 in front) , 1 x microphone (1 in front)
Administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control, DriveLock, HP BIOS Protection, Miracast, HP Drive Encryption, Master Record Security, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, Common Criteria EAL4+
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS Bronze
Efficiency
85%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Software
Sustainability Information
ENERGY STAR Certified
27 cm
31.785 cm
9.5 cm
4.5 kg
10 °C
35 °C
10 - 90% (non-condensing)
