HP ProDesk 400 G2.5 Intel Core i3-4170 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BWV1WS00 Mfr#: M3X16ET#ABU
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
The HP ProDesk 400 SFF with a 44% reduction in size from the previous generation, takes up much less space without sacrificing the computing power and security needed for business computing.
Windows 7 Professional (available through downgrade rights from Windows 8.1 Pro)
Configurations for today and tomorrow
  • Meet your needs and your budget with a reasonably-priced small form factor desktop built for business with customizable configurations.
Safeguard data and devices
  • HP BIOS Protection’s automated recovery restores a copy of the BIOS from a partition on the hard drive if crisis strikes. Protect sensitive business data with the embedded TPM 1.2.
Tested to go the distance
  • HP ProDesks are rigorously tested to help ensure reliability. During the HP Total Test Process, PCs experience 115,000 hours of performance trials to help get you through your business day.
Impressive graphics
  • Immerse yourself in the rich graphic experience provided by Intel® graphics on your HP ProDesk 400 SFF.
Business-class backup
  • Rest easy with dependable business-class support options.
Operating system
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro)
Memory, standard
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Memory slots
2 UDIMM
Hard drive description
128 GB SATA SSD
Processor family
Intel® Core™ processor
Intel® Core™ i3-4170 with Intel HD Graphics 4400 (3.7 GHz, 3 MB cache, 2 cores)
4.5 kg
Weight note (metric)
Exact weight depends on configuration
Graphics
Intel® HD Graphics 4400
Minimum dimensions (W x D x H)
95 x 299.5 x 270 mm
Pointing device
HP USB Mouse
Ports
2 USB 3.0; 1 microphone; 1 headphone jack
Security management
Trusted Platform Module (TPM) 1.2 (Common Criteria EAL4+ certified); SATA port disablement via BIOS; Optional USB port disable at factory (user configurable via BIOS); Removable media write/boot control; Power-on password via BIOS; Security lock slot; Support for chassis padlocks and cable lock devices
Energy efficiency
ENERGY STAR® certified
