Grow your business with the HP ProDesk 400 G2 MT equipped with the tools you need for everyday business.
Configurations for today and tomorrow
Meet your needs and your budget with a reasonably priced business desktop with optional bundled displays ready for expansion and upgrades. -
Designed with work in mind
The newly designed HP ProDesk 400 G2 MT provides easy access to components through the tool-less chassis, front USB 3.0 ports for quick connections and support for legacy ports to support your business. -
Perform at the speed of work
Enjoy the business ready performance of the 4th generation Intel Core processors equipped with a powerful chipset, processor support and robust memory. -
Safeguard data and devices
Help keep sensitive data secure with comprehensive security features like HP Client Security and HP BIOS Protection. -
Guard your data, device and identity with HP Client Security.HP BIOS Protection's automated recovery restores a copy of the BIOS from a partition on the hard drive if crisis strikes.Rest easy with a ProDesk that endures 115,000 hours of testing to help ensure reliability in the most demanding work environments.Rest easy and work confidently with dependable support options including a parts/labor/on-site limited warranty and parts availability for up to 5 years.Optional HP Care Pack with Accidental Damage Protection helps you avoid out-of-pocket repair or replacement costs and delivers service right to your door.
- HP ProDesk 400 G2 - micro tower - Core i5 4590S 3 GHz - 4 GB - HDD 500 GB - TAA Compliant
- Personal computer - micro tower - administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control
- Localisation
- Processor
- Intel Core i5 (4th Gen) 4590S / 3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 4600 Dynamic Video Memory Technology
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, Foxit PhantomPDF Express, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, Box.net 50GB storage, Drive Encryption, HP Disk Sanitizer External Edition (free download)
- 16.5 cm x 35.88 cm x 35.5 cm
- 6.5 kg
- TAA Compliant
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Micro tower
- Built-in Devices
- Speaker
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DVI
- HDCP Compatible
- Max Monitors Supported
- 2
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS SOUND+
- Integrated
- Ethernet Controller
- Realtek RTL8151GH-CG
- Data Link Protocol
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5"
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 3 (total) / 3 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 240-pin
- 4 x USB 2.0 , 2 x USB 3.0 (2 in front) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DVI-D , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE
- TAA Compliant
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
- Efficiency
- 85%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Software
- 16.5 cm
- 35.88 cm
- 35.5 cm
- 6.5 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
