HP ProDesk 400 G1 Intel Core i3-4160T 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BBW4WS00 Mfr#: L9T57EA#ABU
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
  • Red Hat Enterprise Linux
Unclutter your desk with the ultra small HP ProDesk 400 Desktop Mini. Compact yet powerful, this next-gen mini PC packs the performance and industry leading security software you need to work efficiently and safely-at a great price.
  • Power-saving processors
    Help reduce energy use and costs with processors that help consume less than half the energy of those in other mini PCs.
  • Fearless flexibility
    Use it in a kiosk, as digital signage, and more. Plus, take advantage of expandability and compatibility with the HP mini accessories.
  • Connect to more capabilities
    Do more on dual displays with DisplayPort 1.2 and full HD VGA ports, plus use 6 USB ports to plug in all the peripherals you need.
  • Customized protection
    HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
  • Diverse drive options
    Need more than a standard hard drive? Upgrade to an SSD with a full range of choices that fit a variety of needs and budgets, including M.2.
  • Work wirelessly
    Explore your wireless options with M.2 LAN choices, and give your IT team entry level manageability with wake-on-LAN capabilities.
HP ProDesk 400 G1 - mini desktop - Core i3 4160T 3.1 GHz - 4 GB - HDD 500 GB - UK - TAA Compliant
Personal computer - mini desktop - administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control
Intel Core i3 (4th Gen) 4160T / 3.1 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 4400 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Support Assistant, HP ePrint, PDF Complete Corporate Edition, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Drive Encryption, Box.net, HP Disk Sanitizer External Edition (free download)
17.5 cm x 17.7 cm x 3.4 cm
1.3 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.1 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel H81
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Integrated
Ethernet Controller
Intel I217-LM
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 2 (total) / 2 (free) x M.2 Card , 1 (total) / 0 (free) x CPU
4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 (2 rear) , 1 x VGA , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x LAN (Gigabit Ethernet)
Administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
ACPI, FIPS 140-2
TAA Compliant
Power adapter
Power Provided
65 Watt
Efficiency
87%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
OS Certified
Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
Software
Sustainability Information
ENERGY STAR Certified
17.5 cm
17.7 cm
3.4 cm
1.3 kg
10 °C
35 °C
10 - 90% (non-condensing)
