Take on the demands of your growing business with the ultra-slim HP ProBook x360 440. Get the power, security, and durability you need in a versatile 360° design that adapts to the way you work.
Let nothing stand in your way
Power through your day with Windows 10 Pro with built-in security, collaboration, and connectivity. -
Authentic pen experience
Quickly turn thoughts into action with the optional HP Active Pen. Naturally annotate, draw, and take notes on-screen with an authentic experience that feels like a real pen. -
Super secure. Super protected
HP Client Security Manager Gen4 features multi-factor authentication, HP Device Access Manager, HP SpareKey, and HP Password Manager. These tools work to keep data out of reach and defend against theft, attacks, and unauthorized users. -
Browse confidently
Help protect your PC from websites, read only Microsoft Office and PDF attachments, malware, ransomware, and viruses with hardware-enforced security from HP Sure Click. -
Work without interruption
Keep productivity high and downtime low with HP BIOSphere Gen4 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks. -
Field ready
Stand up to the workload with a ProBook that is designed to pass MIL-STD 810G testing.
- HP ProBook x360 440 G1 Notebook - 14" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe
- Display
- 14" WLED touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- ClickPad
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell - up to 13 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- 33 cm x 23.2 cm x 1.99 cm
- 1.72 kg
- Localisation
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz / PC4-19200
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Colour Gamut
- 62.5% sRGB
- Slim Design, Full HD ultra wide-viewing angle (UWVA) BrightView eDP
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Sound
- Stereo speakers, dual array microphone
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, gesture function
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Miracast, dual stream (2x2)
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 13 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB 3.0 (charging) , USB 3.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDXC Card)
Software
- Software Included
- HP Recovery Manager, HP Support Assistant, HP ePrint, HP Velocity, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Workwise, HP Noise Cancellation, HP System Software Manager, HP JetAdvantage, HP PhoneWise, HP Manageability Integration Kit Gen2, Ivanti Management Suite
- Security
- Automatic DriveLock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, ICCP
- Localization
- HP Smart Buy
- 1.72 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
HP Keyed Cable Lock 10mm | In Stock | £26.40 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £109.31 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £138.07 |
Warranty Packs (7)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Pick-Up and Return Service Extended Service Agreement 3 Years | In Stock | £54.13 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £23.19 |
HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site | In Stock | £82.11 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £110.10 |
HP Care Pack Pick-Up and Return Service Extended Service Agreement 4 Years | In Stock | £71.79 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £71.51 |
HP Care Pack NBD HW Support with Defective Media Retention Extended Service Agreement 3 Yrs On-Site | In Stock | £79.17 |
Other bundles (2)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.11 |
