Equip your workforce with HP's most configurable and cost effective notebook PC. Confidently deploy the HP ProBook 655 which combines support for legacy features that provide long-term stability with modern security for today's business.
Easily fits existing IT infrastructure
Help get the most out of existing IT investments with legacy feature support available on the HP ProBook 655 like an optional optical drive,1 native serial ports, a standard VGA port, and an RJ-45 connection.
Cost effective configurations
The HP ProBook 655 is equipped with powerful AMD APUs and offers a wide range of options allowing businesses to configure the right ProBook for each user’s needs.
Professional-grade
Create a full featured experience with powerful processors, robust DDR3 memory, and professional-grade peripheral devices like HP Pro Displays and an HP Ultraslim dock.
Executive-class collaboration
Interact naturally with your PC using an optional FHD Touch screen and Cortana on Windows 10 Pro. Enjoy impressive collaboration tools like Skype for Business, HP Noise Reduction Software, and a 720p webcam for collaboration on the go.
Key Features
Let nothing stand in your way
Be productive in any situation. Experience the new features of Windows 10 Pro on the powerful, touch optional HP ProBook 655.
Customized protection
HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Reduction Software.
Give your speakers a boost
Help make good speakers sound great with the HP Clear Sound Amp.
Tested to go the distance
Stand up to the workload with a ProBook that passed MIL-STD 810G testing.
Protect against minor spills
Help protect your ProBook with a spill-resistant HP Premium Keyboard with backlit options available.
Consistent global deployments
Get the same HP configuration across the globe, available in more than 180 countries where HP conducts business.
Proactively monitor and troubleshoot
Avoid surprises by tracking device health and security policy enforcement. With the HP Touchpoint Manager app, IT can quickly address risks to keep devices functional, and employees productive.
Help get the most out of existing IT investments with legacy feature support available on the HP ProBook 655 like an optional optical drive, native serial ports, a standard VGA port, and an RJ-45 connection. -
The HP ProBook 655 is equipped with powerful AMD APUs and offers a wide range of options allowing businesses to configure the right ProBook for each user's needs. -
Professional-grade
Create a full featured experience with powerful processors, robust DDR3 memory, and professional-grade peripheral devices like HP Pro Displays and an HP Ultraslim dock. -
- HP ProBook 655 G2 Notebook - 15.6" - AMD A10 - PRO-8700B - 8 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Processor
- AMD A10 PRO-8700B / 1.8 GHz, up to 3.2 GHz / 2 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 128 GB SSD
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- AMD Radeon R6
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 37.8 cm x 25.7 cm x 2.74 cm
- 2.31 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD SATA 6Gb/s
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Slim Design, Full HD standard-viewing angle (SVA) anti-glare
Audio & Video
- Graphics Processor
- AMD Radeon R6
- Camera
- Yes - 720p
- Camera Features
- 720p HD movie recording, low light enhancement
- Sound
- Stereo speakers, two microphones
- High Definition Audio, DTS SOUND+
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111HSH
- IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 48 Wh
AC Adapter
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- USB-C , 2 x USB 3.0 , LAN , Dock , Headphone/microphone combo jack , DisplayPort , VGA
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, CyberLink YouCam BE, HP Spare Key, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, Drive Encryption, HP GPS and Location, HP Credential Manager, HP 3D DriveGuard
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- HP 3D DriveGuard, HP SpareKey, HP BIOS Protection, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 2.31 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
