HP Probook 6460b core i5-2410M 2.3GHz 4GB 320GB 14" Windows 7 Professional Laptop
HP ProBook 6460b Notebook-PC
Quicklinx: 7H85WS00 Mfr#: LG641ET#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Professional assistant. Get the job done. From writing reports to attending mobile meetings, this HP ProBook with a 14.0-inch diagonal HD display is the perfect professional assistant for everyday business tasks.
  • Professional design
    Boasting an elevated level of design, the HP ProBook 6460b sports a bead-blasted aluminum display enclosure, a magnesium-reinforced ABS chassis, and a bottom case with drain that helps protect against accidental minor spills. The full-sized keyboard allows you to type quickly and is conducive to using gestures.
  • Enhanced performance and graphics
    Create documents, presentations, and spreadsheets, and quickly share them with coworkers. The Intel Core processor offers incredible performance, responsiveness, and enhanced graphics.
  • Legibility and portability
    Enjoy the easy-to-view 14.0-inch diagonal display on the HP ProBook 6460b.
HP ProBook 6460b - 14" - Intel Core i5 - 2410M - 4 GB RAM - 320 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit
Intel Core i5 (2nd Gen) - 2410M / 2.3 GHz, up to 2.9 GHz / 3 MB Cache
4 GB DDR3
Storage
320 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
14" LED backlight HD anti-glare 1366 x 768 / HD
Graphics
Intel HD Graphics 3000
Integrated Webcam
802.11b/g/n, Bluetooth 2.1 EDR, Gigabit Ethernet, fax / modem
6-cell - up to 7.25 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip
33.8 cm x 23.1 cm x 3.4 cm
2.3 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Recommended Use
Small business, corporate business
Operating System
Processor / Chipset
CPU
Intel Core i5 (2nd Gen) 2410M / 2.3 GHz
Max Turbo Speed
2.9 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Chipset
Mobile Intel HM65 Express
Intel Turbo Boost Technology 2.0
RAM
4 GB
Max RAM Supported
16 GB
DDR3 SDRAM
Speed
1333 MHz / PC3-10600
Rated Speed
1333 MHz
SO-DIMM 204-pin
Slots Qty
2
Storage
Main Storage
320 GB HDD SATA 3Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM removable
Disc Labeling Technology
LightScribe Technology
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
HD anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Dynamic Video Memory Technology
Camera
Sound
Stereo speakers, stereo microphone
SRS Premium Sound
Input
Keyboard, touchpad
Spill-resistant
Communications
Wireless
Wireless Controller
Broadcom 4313GN
Network Interface
Gigabit Ethernet
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3az
Modem
Protocols & Specifications
ITU V.21, Bell 212A, ITU V.22, ITU V.22bis, ITU V.29, ITU V.32, ITU V.32bis, ITU V.34, ITU V.17, ITU V.23, ITU V.27ter, ITU V.8bis, Bell 103J, ITU V.92, ITU T.30, ITU T.4, ITU V.250, ITU V.251, ITU V.80
Fax Compatibility
G3
Max Transfer Rate
56 Kbps
6-cell Lithium Ion
Installed Qty
1
Max Supported Qty
2
55 Wh
Run Time
Up to 7.25 hours
AC Adapter
Input
Output
65 Watt, 18.5 V
Connections & Expansion
Expansion Bays
1 x Upgrade Bay
Slots
1 x ExpressCard/54 (1 free)
Interfaces Details
DisplayPort , VGA , FireWire , Microphone input , Headphone output , Modem , LAN , 3 x USB 2.0 , USB 2.0/eSATA , Dock , Battery
Memory Card Reader
Yes (SD Card, MultiMediaCard, MMCplus, SDHC Card, SDXC Card)
Software
Software Included
HP ProtectTools Security Manager, Skype, HP Recovery Manager, HP Support Assistant, HP QuickWeb, HP Power Assistant, HP DayStarter, HP SoftPaq Download Manager (free download), PDF Complete Special Edition (60 days trial), Norton Internet Security 2011 (60 days subscription), HP Connection Manager 4.0, HP Hotkey Support, Roxio Secure Burn, HP ProtectTools for Central Management
Dockable
Security
Security lock slot (cable lock sold separately), HP Disk Sanitizer, HP 3D DriveGuard, Enhanced Pre-Boot Security, HP SpareKey, One-Step Logon, HP File Sanitizer
CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES
Localization
HP Smart Buy
2.3 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance
125 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
