Take on tasks in the office or on the road with the durable HP ProBook 645 and HP ProBook 655. These ProBooks are thin, light and a great value. Enjoy enhanced productivity and do more – faster and better – to meet the most demanding workloads.
Thinner, tougher taskmaster
Get the technology you trust from HP, with modern style that looks and feels the way you want. Join forces with the latest generation technology and legacy features your business demands on a thinner HP ProBook for in the office or on the go. Protect existing IT investments with support for existing legacy features such as an optical drive, VGA and RJ45 connectors. -
Convenient control
Protect data, devices and identities with HP client security and use HP trust circles to make sure only assigned contacts can access critical files. Keep sensitive information in safe hands. HP trust circles protect your data by ensuring that only approved contacts can access critical files. Stay up and running. HP BIOS protection offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.
- HP ProBook 645 G1 Notebook - 14" - AMD A6 - 5350M - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit
- Processor
- AMD A6 5350M / 2.9 GHz, up to 3.5 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 14" LED backlight HD SVA eDP anti-glare 1366 x 768 / HD
- Graphics
- AMD Radeon HD 8450G
- Input Device
- Pointing stick
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 6-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 34 cm x 23.7 cm x 2.9 cm
- 2 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- Chipset
- AMD A76M FCH
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM removable - tray
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- DTS SOUND+
Input
- Keyboard, touchpad, pointing stick
- Spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Remote Management Protocol
- SNMP
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 6-cell Lithium Ion
- Capacity
- 55 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 18.5 V
Connections & Expansion
- Expansion Bays
- 1 x Upgrade Bay
- 4 x USB 3.0 , DisplayPort , VGA , Microphone input , Headphone output , LAN , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, CyberLink YouCam BE, HP Spare Key, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Box.net 50GB storage, Drive Encryption, HP Trust Circles Standard, HP Disk Sanitizer
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- DriveLock, charging via USB, HP Disk Sanitizer, HP 3D DriveGuard, HP SpareKey, HP File Sanitizer, soft-touch surface, HP BIOS Protection, Automatic DriveLock, SecureBoot, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, FIPS 140-2, WEEE, A-Tick, ICES, Common Criteria EAL4+, FIPS 201, KC, CIT
- Localization
- 2 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
