HP ProBook 640 Core i5-6300U 8GB 256GB SSD 14" Win 10 Pro
Quicklinx: D52FWS00 Mfr#: Y3B61EA#ABU
Display Size: 14in
Processor Model: I5-6200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
Hurry, only 1 left in stock!
£773.99 ex VAT
£928.78 inc VAT
Equip your workforce with HP's most configurable and cost effective notebook PC. Confidently deploy the HP ProBook 640 which combines support for legacy features that provide long-term stability with modern security for today's business.
  • Easy integration
    Help get the most out of existing IT investments with legacy feature support available on the HP ProBook 640 like an optional optical drive, a VGA port, and an RJ-45 connection.
  • Powerful processing and drive options
    Select from powerful 6th Gen Intel Core processors and integrated Intel HD UMA graphics along with other configurable options that let businesses configure the right ProBook 640 for each user's needs.
  • Professional-grade
    Create a full featured experience with powerful processors, robust DDR4 memory, and professional-grade peripheral devices like HP Pro Displays and an HP Ultraslim dock.
  • Executive-class collaboration
    Interact naturally with your PC using an optional FHD Touch screen and Cortana on Windows 10 Pro. Collaborate clearly with optional Skype for Business, HP Noise Reduction Software, and a 720p webcam.
HP ProBook 640 G2 - 14" - Core i5 6200U - 8 GB RAM - 256 GB SSD - QWERTY UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz) / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB - M.2 SSD
Optical Drive
DVD SuperMulti
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
34 cm x 23.7 cm x 2.7 cm
1.95 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000 - 2133 MHz
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2) SATA
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Slim Design, Full HD standard-viewing angle (SVA) anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
High Definition Audio, DTS SOUND+
Input
Keyboard, touchpad
Keyboard Layout
QWERTY UK
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
48 Wh
AC Adapter
Output
45 Watt
Connections & Expansion
Slots
1 x SIM card (1 free)
USB-C , 2 x USB 3.0 , LAN , Dock , Headphone/microphone combo jack , DisplayPort , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Drivers & Utilities, CyberLink Power2Go, HP Recovery Disc Creator, Skype, LANDesk Management Suite, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, Password Manager, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOSphere, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), Absolute Persistence, HP CIK for Microsoft SCCM (free download), HP Noise Reduction Software
Case Material
Polycarbonate ABS
Dockable
Security
HP 3D DriveGuard, soft-touch surface, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
1.95 kg
ENERGY STAR Certified
Software applications
HP ProBook 640 Core i5-6300U 8GB 256GB SSD 14 Bundle deal on HP ProBook 640 Core i5-6300U 8GB 256GB SSD 14" Win 10 Pro
£959.21
saving £8.33
£873.16
Display Size: 14in
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Graphics: Intel HD Graphics 520
Hard Drive Type: SSD
Touchscreen: No
Type: Laptop
Brand: HP
Price Range Ex VAT: 750 - 1000
