HP ProBook 470 Intel Core i5-4210U 4GB 750GB 17.3" Windows 7 Professional 64-bit
Quicklinx: B12JWS00 Mfr#: K7J31EA#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
  • Bluetooth 4.0
The attractive HP ProBook 470 G2 with its 43,9 cm (17.3") diagonal, optional FHD screen and latest generation technologies delivers powerful performance in the office or on the go. Proven reliability and comprehensive HP security features help keep your data and investment protected.
  • Let nothing stand in your way
    Be productive in any situation. Experience the new features of Windows 10 on the thin, light, HP ProBook 455.
  • Tested to go the distance
    Rest easy with a ProBook that endures 120,000 hours of testing to help ensure reliability in the most demanding work environments.
  • Help secure critical data
    With TPM your critical data has protection with hardware-based encryption keys.
  • Protect against minor spills
    Help protect your ProBook from minor spills with an optional backlit spill-resistant HP Premium Keyboard.
  • Proactively monitor and troubleshoot
    Avoid surprises by tracking device health and security policy enforcement. With the HP Touchpoint Manager app, IT can quickly address risks to keep devices functional, and employees productive.
  • BIOS protection
    The hardware root of trust BIOS design inspects the integrity of the BIOS code during each boot verifying the code ensuring only HP approved code executes at start-up.
HP ProBook 470 G2 Notebook - 17.3" - Intel Core i5 - 4210U - 4 GB RAM - 750 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Intel Core i5 (4th Gen) - 4210U / 1.7 GHz, up to 2.7 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
750 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
17.3" LED backlight 1600 x 900 / HD+
Graphics
AMD Radeon R5 M255 / Intel HD Graphics 4400
Video Memory
2 GB DDR3 SDRAM
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
6-cell - up to 10.25 hours
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader
41.38 cm x 27.95 cm x 3.22 cm
2.84 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
CPU
Intel Core i5 (4th Gen) 4210U / 1.7 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
750 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM fixed - tray
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1600 x 900 (HD+)
Widescreen
Image Aspect Ratio
16:9
HD+ standard-viewing angle (SVA)
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB DDR3 SDRAM
Video System Features
AMD Dynamic Switchable Graphics
Camera
Yes - 1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
Realtek ALC3227-CG
DTS SOUND+
Input
Keyboard, touchpad
Numeric Keypad
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Wireless Controller
Realtek RTL8723BE
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8161GSH-CH
Remote Management Protocol
SNMP 2
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
6-cell Lithium Ion
51 Wh
Run Time
Up to 10.25 hours
AC Adapter
Input
Output
65 Watt, 18.5 V
Connections & Expansion
2 x USB 3.0 , 2 x USB 2.0 , HDMI , Headphone/microphone combo jack , LAN , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, HP Setup, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, Intel Wireless Display, HP Wallpaper, HP Spare Key, HP Registration, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Box, HP Disk Sanitizer, HP Ceement, HP Validity Fingerprint Driver, HP DigitalPersona Fingerprint Driver, HP Software Setup, HP GPS and Location
Security
HP Disk Sanitizer, HP 3D DriveGuard, HP SpareKey, HP File Sanitizer, HP BIOS Protection, Automatic DriveLock, BIOS Absolute Persistence, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, WEEE, A-Tick, ICES, KC, CIT
Localization
2.84 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
