HP ProBook 470 G5 17.3" Intel Core i7-8550U 8GB 256GB Win10Pro
Quicklinx: DDYMWS00 Mfr#: 2RR84EA#ABU
  • Core i7
Full-featured, thin, and light, the HP ProBook 470 lets professionals stay productive in the office and on the go. Stylish design, linear precision, and subtle curvature plus optional Quad Core performance and long battery life make this ProBook essential for today's workforce.
  • Let nothing stand in your way
    Experience the new features of Windows 10 Pro on the thin and light HP ProBook 470.
  • Protect your data with multi-factor authentication
    Fortify your security by using multiple factors of authentication including fingerprints and facial recognition.
  • Storage options
    Get the best of both worlds with dual solid-state and hard drive storage options from HP.
  • Outstanding battery life and fast charging
    Battery life that gets you through the workday and beyond. Fast charge 90% in 90 minutes.
  • Stay Connected
    Stay connected with HP Connection Optimizer self-healing wireless driver technology and support for the latest global 4G LTE wireless broadband technology.
  • Tested to go the distance
    Stand up to the workload with a ProBook that passes MIL-STD 810G testing.
HP ProBook 470 G5 Notebook - 17.3" - Intel Core i7 - 8550U - 8 GB RAM - 256 GB SSD + 1 TB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) - 8550U / 1.8 GHz, up to 4 GHz / 8 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe, TLC, HP Value + 1 TB HDD / 5400 rpm
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA GeForce 930MX / Intel UHD Graphics 620
Video Memory
2 GB DDR3 SDRAM
Input Device
ClickPad
Keyboard
Numeric Keypad
Integrated Webcam
Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
41.38 cm x 27.6 cm x 2.25 cm
2.5 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 8550U / 1.8 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe), triple-level cell (TLC), HP Value
Secondary Storage
1 TB HDD SATA 6Gb/s / 5400 rpm
Display
17.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Colour Gamut
45% sRGB
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Premium
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB DDR3 SDRAM
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
Input
Keyboard, ClickPad
Keyboard Layout
Numeric Keypad
Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111HSH
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
3-cell Lithium Ion
48 Wh
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Interfaces Details
USB 2.0 (powered) , 2 x USB 3.1 Gen 1 , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , HDMI , Headphone/microphone combo jack , LAN , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Velocity, HP Secure Erase, HP Client Catalog, HP BIOS Config Utility, HP 3D DriveGuard 6, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP JetAdvantage, HP Wireless Wakeup, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Connection Optimizer, HP BIOSphere Gen4, HP Driver Packs (free download)
Security
HP DriveLock
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
Localization
2.5 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
